Tiny Small Mini Tamiya Cooper Rover (fun sized)
Small Factory
Fancy-Walkin'
I don't own any lexan cars. Honestly, none of them have ever interested me except the Tamiya Mini Cooper. I never got myself one 20ish years ago when they were available, and always wish that I did.
I was on the worlds largest online auction site, and I saw a new in box body with decals for sale, in the USA, for a very reasonable buy it now. I thought about its, then bought it then.
Since unpainted versions of this body is very rare, I sent it out to Moosejaw Joe for painting, since I do not own any lexan paints, dislike the process of painting lexan, and certainly did not want to experiment on this.
Here are some pictures for your viewing pleasure.
Small Factory
Fancy-Walkin'
For the M-class chassis, there a basically 3 choices as far as I can tell: The M01/M03/M05/ect from Tamiya, for the serious track racer, there are the offerings from rc-xpress, and then MST has in interesting new offering as well called the TCR-M.
I went with the TCR-M due to it's very simple, but flexible layout. You can build it in 2 different track widths, and 4 different wheelbases. It also can be built in a front motor/FWD, mid motor/RWD or read motor/RWD. I built it in the smallest width/wheelbase as a FWD.
Since this is only for my driveway. I went with a 35-turn on 2S. It was to fast on 3S for my allotted space, plus I don't want to destroy the body.
It's basically a Tamiya F1 gearing setup with some king-pin suspension.
  • Like
Reactions: JMo
JMo
Hee hee - love it! (well, except the lexan)...
I had a plan to build a Project Binky replica at some point - using the Tamiya MF-01x 4wd chassis, although I like that you've got the motor mounted up front in this iteration - that MST is an interesting chassis option!
JMo
Out of interest (and not wanting to derail this thread of course) - do you know if it's possible to line a lexan shell with fibre-glass matting, to basically give it more rigidity - or would the resin melt the lexan?
I was thinking that a shell like this (or indeed any 'motorsport' application) might look good in raw fibreglass with effectively a lexan 'gel-coat' over the top if you see what I mean? - and you could always paint it externally, then if/as the paint wore you'd see the fibreglass showing underneath?
Small Factory
Fancy-Walkin'
I am sure someone has tried it. I know metal masher makes molds from lexan bodies all the time, then uses the mold for his aluminum bodies. I imagine the biggest issue would be the ability to not have the fiberglass weld to the lexan.
  • Like
Reactions: JMo
JMo
Yes, sorry that was what I meant - basically to leave the lexan shell as a 'gel coat' on top of the fibreglass, so I would want the two joined together so the whole assembly is thicker/more rigid - just not have the resin actually dissolve the lexan.
I might have to try it!
