Wrencher
Moderator
A very easy method to finish parts with out sanding. I used this method on the wheels for the Icon FJ44 wheels i felt it worked very good. Just make sure you do a couple light coats and dont try to apply it too thick. here is the video that I learned from.
On some smaller parts I also tried an even easier method. First I would spray the model with a thin coat of flat primer. Once that had dried I sprayed over primer with some gloss paint. The gloss seems to settle in the low spots of the layer seams. Once that has dried really well, Paint over the gloss with what you want your top layer or finish to be. I found it worked very well on parts that where to small to sand. just enough to hide the layer lines a bit.
Hope this helps.
Chris
Hope this helps.
Chris
