RexRacer19
Let me 3D print that...
Change the looks and performance of the Axial SCX24 with this roll cage. It has a more compact style overall and and is 6 grams lighter than the factory roll cage (3g vs 9g). It mounts using the factory screws and does not require any modification to the body. It can be purchased in black, or white if you would like to paint it yourself and save a couple of dollars.
**IMPORTANT** You should use either a 1.1mm or a #57 (.043") drill bit to clean out the screw holes. There is always a small amount of unsintered powder left in deep holes despite the cleaning process. Not cleaning the holes out prior to mounting will likely cause the screws to not go all the way in and possibly stripping out the holes.
Product Link: https://www.shapeways.com/product/8HRJPECJC/scx24-roll-cage-style-a?optionId=108774878
Thanks for looking! Please post any questions below.
