DayGeckoArt
I wanted to run Tamiya Lunchbox wheels on my SCX10 so I designed 3 piece wheels. They're narrower than the originals. When you screw the wheel onto the hub, the rims go together and pull in the sidewalls, making them stiffer. Foams can be used but the tires function like real flotation tires without foams. The 6 "bolt holes" are there so you can put in a custom hub to make them look more like real tractor wheels. The sleeve locks the two rims together so the tire doesn't twist.
Download link: https://makerworld.com/en/models/2810848-lab-808-tamiya-lunchbox-wheel-for-rc-12mm-hex
