HUM 3d question?
Yes, with a giant BUT.
I paid through the nose for them to convert to a printable file. And it'll still need a ton of work on your end to slice it to fit on a printer, and it'll likely have a full interior you'll need to trim out, etc. Never mind all the little bits and pieces to separate so you can print them in a higher res.
Not for the faint of heart, or light of wallet.
born to crawl
Almost seemed too good to be true. Thanks for the tip
Cesco
This might be a better option.
https://www.scale3drc.com/
I just finised printing one of their bodies. Quality is good. Print files are not expensive. They are however non-licenced, but for most it it pretty clear what the original model is. No interiors and you have to figure out body posts and windows yourself. Offcourse if you add all that and add some logo's, you will end up with something special.
It is sure a good alternitave for a ABS body. And less to mess with the files.
