First venture into designing something other than small crawler parts
CrashRecovery
Been a lurker on here and Discord for some time. I've got a buddy who is finishing up a roller of a 1:10 scale Kenworth Cabover for me, so I needed a trailer. Lowboys seemed too common, so I went for something else, a tilt deck trailer. To make things even harder, I wanted it to tilt and for the trailer axles to slide as they do on the real trailer. I'm not great with CAD, so this has been a learning experience. I'll eventually be buying a new 3d printer so I can print more than PLA and PETG, just haven't picked out the unit I want to get. In the meantime, I figured I'd start fiddling around with Fusion 360.
So this is trailer style I'm going for.
I used the canvas function to scale the design. I used this to get my basic design done, and then I kept changing things.
Started with this,
Then exploded it into components,
I fiddled with the design and realized I had to fix the rear so the axles could sit farther back.
After some searching, I found that the Tamiya 1:14 scale trailer tires were a perfect fit, so I'm considering using a few parts from those trailers to build the sliding rear axle setup.
So I'm at this point now.
Probably going to use a pair of these linear actuators with the 30mm stroke for the tilt function.
Once I get a working 3D printer, I can start testing the design and making adjustments. As I progress, I'll keep posting updates.
ddmckee54
How much room do you have for the actuators? The actuator that you have shown looks like the N20 Type 7 gearmotor I'm going to use in scissors lift for my RT7R project.
AP1GczMxQ-vAZj9dMxjfZR8bxrEWqA0_qWLiIQoKMy3ZOPoJ6Xpr4UnxQbHP_AOBlcQupfvyIcos01O_aW3AZ0YgRUmoMT7AU0dVnjjWztvFa3DWAj2EMqIlFsUiDepdpScQH-XGrNn6L_ucJKGIq1hcWVmu=w640-h334-s-no-gm
The M4 screw in that guy is 55mm long, but I only need about 15-20mm of travel.
CrashRecovery
I'll call this part of the trailer the top deck part. That back section of the "fork" area is 36mm tall, and I have about 130mm or so of "length." The real trailer actually mounts the hydraulic rams down at the bottom of that section, the circled portion of this screenshot.
I might play with the design and the lower mounting tabs to see how that looks. Right now, I'm just looking to get the rough design done. If my Ender 3 were working, it would take days to print out the key parts I need to test this idea. I just haven't settled on what brand of printer I want to get. This will probably be the biggest project I ever print out so, I don't think I need one of the "XL" printers. The longest part of this, the bedside, is just under 1250mm. I can split that up into multiple pieces and either add openings for carbon tubes to reinforce the structure, or I could recess a space inside the part to hold a thin piece of aluminum or a thin steel plate. IDK, I've got a couple of ideas for that as well. I've used replacement towel bars in the past for a couple of multirotor projects I built. I could cut these into "angle iron" and use that to support the side pieces.
Replacement Towel Bar
I've got too many "ah ha" ideas right now when it comes to how this is going to be built. As I mentioned, this project is in its early stages, but it will probably be one I follow through to the end.
BigRuss
The engineering involved to make this work is astonishing. Can't wait to see the progress this makes.
CrashRecovery
I'm curious why you can't use PETG for this model
I probably could; however, my old Ender 3 Pro needs a lot of work before I can get it back up and running. Either the hot end or the bed heating element keeps failing and causing errors. The printer won't complete the initial preheat. I probably never used the printer enough, and when I did, it would take 3 or 4 calibration prints to get it working. I want to try some stronger filaments eventually, but they require heated chambers. I also want the ability to use different filaments while printing, like for supports. It's going to be a long road with this project.
DayGeckoArt
I got a Bambu A1 Mini a few months ago as my first 3D printer and when I can afford it, I want to get the H2D with dual nozzles. I want to try combining PETG and TPU in the same print. One idea I have is control arms or other linkages with integrated bushings. Another one is parts that are TPU on the outside with PETG inside for more stiffness, or vice versa.
I've found that Overture PETG is stiff when the parts are designed for rigidity. It seems like it would work fine for your design. There seems to be a lot of variation between brands though. Sunlu is softer and shinier
CrashRecovery
I've been using the overture petg since I started 3d printing. It was suggested to me from the guy who runs Crawlers N Customs. I'd love to try some abs or any of the cf combinations out there but you need hardened tip and a heated chamber depending on the material.
CrashRecovery
Decided to play with screenshots and record the movement of the rear axles. Right now I'm just reviewing the design.
https://flic.kr/p/2rNXmdv
The question of the day for this is, do I figure out some way to use a servo winch to move the axles back and forth or do I move them manually and use a screw to lock them in place when I want to use the trailer for towing?
ddmckee54
What about a lead screw between the frame rails? 3D printer lead screws are fairly cheap, you can get them in a variety of lengths, and they've got enough pitch that you don't need a lot of rpm to be able to move the bogies at a reasonable speed. Most printer lead screws have a 2mm pitch, so a 100 rpm gearbox would move the axles at 200mm/minute. A low speed N20 gearbox MIGHT run it, and those are only 10mm thick. Those little motors are what drive most of the mini linear actuators. Or, going with a 25mm gearmotor should be more than enough to get the job done - if you've got the room for it. With a lead screw you probably wouldn't have to lock the axles in position.
CrashRecovery
What about a lead screw between the frame rails? 3D printer lead screws are fairly cheap, and they've enough pitch that you don't need a lot of rpm to be able to move the bogies at a reasonable speed. A low speed N20 gearbox MIGHT run it. Those little motors are what drive most of the mini linear actuators. Or, going with a 25mm gearmotor should be more than enough to get the job done - if you've got the room for it. Most printer lead screws have a 2mm pitch. so a 100 rpm gearbox would move the axles at 200mm/minute.
Well..... ding ding ding we may have a winner. Sounds like i need to design a box for the top deck to house an Arduino and escs for actuators and screw drive.
ddmckee54
"Well..... ding ding ding we may have a winner. Sounds like i need to design a box for the top deck to house an Arduino and escs for actuators and screw drive."
Or maybe just a small battery pack and a couple of toggle switches?
CrashRecovery
If I can't figure it out the arduino and make work it with my nobel 4+ the 3 position switch idea might be an option.
CrashRecovery
The Arduino can't directly drive much of a load, I think it maxes out at 30-40mA.
The Arduino would be more of a timer and sends a singlal to the esc to control how long to run the motors. I haven't explored the programming on the nobel to see if it can do that. It might.
