i have started runing semi-droop on my Venom Creeper with great sucess. I went to the local hardware store and got a box of assorted spings that fit INSIDE the shock body.
Pull the shock apart.
Place a soft spring about 3/4 the lenghth of the shock body inthe shock and replace the plunger/shaft.
Now find a short spring and put it on top of the plunger inside the shock.
cap the shock and fit to truck.
The idea is the truck is riding on the small spring most of the time. This gives a nice low centre of gravity with a reasonably smooth ride. The long spring helps control the droop aspect of suspension travel The weight of the wheel/tyre set up pulls the wheel down against the spring keping it in contact with the ground.
Sounds weird but works a treat,can be tuned by adding weight to wheels, changing springs or adding shock oil to slow movment.
Added bonus is at full compression spings act as limiters for suspension travel allowing you to carry a wheel rather than drop it into a hole that it may get caught in.
Also keeps a more standard ride hieght with scalers but adds articulation (taniya CC-01 rear end?)
