Good morning. Although I’ve always liked the Zil 130, the steering angle is severely limited with the tires I want to use—they rub against the leaf springs, the BRX80 axles, and the steering knuckles; adding wheel spacers improves the turning angle but causes excessive rubbing.
So, I’ve decided to modify the chassis Wwith 2XL rails and a BRX90 axle conversion kit; it’ll be fitted with an RC4WD K10 body. I’ll keep you posted on the progress.
For now, it’s time for a cleanup—once I removed the body, I realized I hadn't even seen half the grime that had built up in there—and then I'll assemble the chassis parts.
It’s been an entertaining morning; I had to reposition the servo winch and print a receiver box, but it’s all set for when the body arrives. Honestly, having a printer right there—along with a community of people who design and share files—is a huge plus; it’s really cool. The side and rear mounts, as well as the electronics box, are pre-made designs I bought on Cults3D (not the free ones), but they’re well worth the cost—the fit and finish are amazing.
The 2XL chassis rails are installed, the BRX90 kit is assembled, and everything is pretty much ready to go, save for the usual final tweaks.
