JMo
Welcome to my latest and also longest project... originaly started back in 2019 when I first moved to the US full time, and which has sat on a shelf indefinitely until now - hence the title: Car 72 [No Activity] - IYKYK.
A brief history...
The idea was always to build a SCORE Class 5 style Baja Bug - loosely based on the Sand Scorcher of course, but with my own twist on the underpinnings - starting with a custom chassis (cut from 2mm aluminium) which would better replicate a full floor pan, and at the time my intention was to incorporate proper trailing arm suspension too - although as we'll see in the photo montage below, this threw up a succession of issues which ultimately meant I've reverted to an SRB rear end too:
Note for the sake of brevity, I've omitted the very first mock up, which actually used twin chassis rails, and featured a mid-rear motor and a live rear axle on 4-link trailing arms, mainly because it was too experimental - and would confuse the narrative... however, if you're interested, there is a legacy thread HERE on TamiyaClub which shows the original evolution of this project in more detail.
photo. V2 mock up way back when - using a Monster Beetle shell and Axial transmission, and some aluminium trailing arms from a Kyosho buggy.
photo. custom chassis to tie the front and rear subframes together (although the rear shock mounts were still very far away in my imagination)...
photo. unfortunately practically speaking this motor orientation meant the engine was sitting far too high in the back of the car...
photo. V3 flipped the motor forward (in more of a transverse mind-engine layout), and I also incorporated one of Alberto's prototype cages which became the AMPro/Knight Customs Class 5 Baja Bug project (foreshadowing!)
This was better, however the chassis and ground clearance was compromised by mounting the Axial transmission in this way, and I factored that if I was going to have that kind of [transverse motor] gearbox layout, then I might as well just use an SRB transmission after all eh? So I did:
photo. yes, I got though a lot of aluminium sheet cutting multiple versions of what was ostensibly the same chassis plate in an effort to dial in the various gearbox and rear suspension layouts...
photo. V4 was arguably the best iteration so far - an SRB gearbox, and proper metal trailing arms too - although it did mean the rear track width was overly wide unfortunately...
photo. V5 reverted to using an SRB gearbox together with the stock wishbone rear suspension arms too, which meant I could also incorporate the roll hoop as a suitable rear-shock mounting location - we're getting somewhere at last! note. fortunately due to the re-release of the Sand Scorcher, Buggy Champ and Fighting Buggy since 2010, there is a steady supply of SRB suspension and transmission components available from retailers and Ebay kit splitters these days.
photo. and yes, for the penultimate incarnation, I elected to install the Fighting Buggy (Super Champ) rear suspension, if only to mix things up from my other SRB based build the SRB Cage Racer which features a scale Knight Customs engine out back.
And that is basically how it stood for a couple more years - just sitting there, doing nothing... while I eventually robbed the Scorcher body for my Beetle-Juiced project, although was subsequently re-inspired once I'd built the Optic-al Illusion, and had another Knight Customs Terra Bug nose scaled and printed to fit the front end:
photo. hmmmmm... I think this could be finally something I wanted to finish!
cont.
A brief history...
cont.
