1933 Diamond T Texaco Special (aka Doodlebug)
fab1ten
Ever since I first saw a picture of this vehicle, it has intrigued me. It is so different from anything we would see on the roads today and was actually pretty different in its own day also. Officially known as the Diamond T Texaco Special, it also became known as the Doodlebug due to its shape.
It was built to be a fuel tanker capable of getting into smaller forecourts. Considering its 1500 gallon capacity, it was a surprisingly small vehicle. Originally one prototype was made followed by a production run of six more. Sadly, no one knows what happened to them and none exist today. If you want more info on them, there is some very good research here:
I have been wanting to develop more skills in metal shaping. Now I could try to build a replica E-type Jaguar from scratch, but I thought maybe starting with something smaller might be a good idea. So I have decided to do a model of the Doodlebug in 1:10 scale. It will be an almost total scratch build as I don't plan to use any existing kit parts for this. It will also be mostly, if not completely metal. I plan to form the body from 0.030" steel. It will be rear engine/rear wheel drive, like the original.
This will be a challenge with a lot of learning to do. I'm going to need some more tools as well....
fab1ten
First step was to layout the design in CAD to get the basic lines for the vehicle. Conveniently, the research I did turned up a copy of the original patent drawings filed in 1933 which give the top, side and cross-section views. Perfect. Well, all was not quite so perfect when I started scaling them to make drawings. It seems that the height-to-width ratio is different in the cross-section views vs the top and side views. So I had to average a few dimensions, but eventually I came up with a 3D wireframe model I was happy with.
You can see the wireframe lines in faint blue. Overall, the model will be about 31 inches long x 9.2" wide x 8" tall.
From those lines I created cross-sections and created ribs to build up the frame that will support the body panels. Actually, in 0.030" steel, the body will be quite strong and capable of supporting itself without any framework, so the framework is primarily there to help me shape the steel to the correct profile. Later I will probably make use of the frame pieces as mounting points for the chassis and running gear, etc.
Next step was getting all the skeleton parts laser cut from 0.060" steel.
I included tabs and slots to make assembly easier and more accurate.
Next job will be to braze that lot together.
Frizzen
Very cool start of a project!
Your all steel body Texaco Special is going to be a beast, can't wait to see how this goes together
I love that the frames and stringers have lightning holes
fab1ten
The lightening holes are a bit of a laugh really when you consider how much this thing is going to weigh when it's done. I suppose mostly they just make the parts look better.
I'm not too concerned by the weight anyway. This is hardly a performance vehicle and the weight will make it ride more realistically.
Hoo boy this will be good! I wish I had a laser cutter!
I wish I had a laser cutter too, but the next best thing is access to one at the local university. Without one, it's just a case of a few hours on the bandsaw and clean up with a file (and skip the holes!). Done that many times.
RSRC
This should be an interesting read. Lots of problems to solve making that body, I'll quite enjoy seeing how you tackle them.
Not looking for any spoilers ahead of time, but I'd guess there's some english wheel work forthcoming...
fab1ten
There certainly is some wheel work coming. That was one of the motivations for this build. Forming complex curves in sheet metal is something that has always interested me, but something I have almost no experience with. This project will give me a chance to learn some new skills in that area.
This is possibly the coolest retro build of all time.
I hope it lives up to expectations when it's all done. I'm really liking the flowing curves of 1920's & 1930's streamliner vehicles. If this one works out, I may do a few more.
imthejaybird
I'm here...
I'm excited to watch this grow. For all the same reasons that the others have mentioned, but also because my grandfather retired from Texaco. So, there's a soft spot in my heart for all things Texaco. I still have a lot of the little truck banks he got for me when I was a kid.
Also, new tools!! Always a good time! A bench top mill and lathe, and an AC/DC TIG are on my list. Might have to sell a kidney, but one of these days I'll get them.
fab1ten
So do you have the coin bank for this vehicle? I picked up one a few months ago when I got interested in doing this model. I think it is a modern reproduction though, not a vintage one.
Frizzen
Do you plan for this to be the 'short sill/small vent' or 'wide sill/big vent/marker' version, or just one from a fictional 3rd production run of tankers?
Once you get the learning curve for the panels on the Special, you'll be ready for scale Airstreams and all kinds of sweet 1920-40s builds!
Watching this get rolling is really going to ramp up my excitement to get going on a much later truck i've been gathering parts to build.
You can trust your car to, the man that wears the star....
imthejaybird
I'm here...
No sir I don't. I wish I did, that would be a nice one to have. My Uncle worked for True Value back then too, so I've also got a few TV truck banks from there.
fab1ten
Right now I am planning to do the wide-sill version mostly because it has a few more outside details, such as the marker lights which I plan to make functional. For the most part, aside from minor details, the two versions are pretty similar.
The TEXACO lettering on the outside will be interesting to do. At first glance you might think it is painted on, but in fact it appears to be individual letters cut from steel and mounted on stand-offs slighty above the body surface. I plan to copy the same technique on the model, however it will make transporting the model a nightmare with all those fragile letters just waiting to catch on something and get bent out of shape.
fab1ten
I got all the bits brazed together. It mostly went to plan with only a little straightening and truing up required after brazing.
The two side profile pieces at the front and back are not brazed on. They are guide templates to help me get the correct shape, but they won't be part of the final body shell. Basically, they are not needed for strength (the nose and tail cones will be strong enough on their own) and attaching them would just create unnecessary work (which I have plenty of already).
The areas where the wheels go will be cut out later. You can see the steps in the ribs where the wheel wells will be attached. I created ribs across those points to help me get the body to the correct contour. With a shape like this, it's much easier to create a clean body and then cut out the openings, than to form the body skin around existing openings.
Lastly, I added a couple flanges to the end bulkheads. These will keep the separate body skins in alignment where they meet and also strengthen the joint.
Next step will be the main body skin, which is the easy bit since it is a simple curved shape rather than the compound shapes to come later.
Bystickel
This is off to an excellent start!
I'm contemplating making a smaller-scale English wheel for a project I have been planning. (I have very limited experience forming) I am looking forward to learning along with you.
Maybe you can use it to deliver nitro to 1/8th buggy racers ;)
