AE Element
Page 4 of 10 FirstFirst 12345678 ... LastLast
Results 31 to 40 of 92
Thread: Winch building tutorial
  1. #31
    Burnaby, BC
    That's great Darwin! I'll get on this soon.
  2. #32
    Rockfrog Guest
    I'll commit to buying one as long as it'll swap into a standard size servo. would it be compatible with a digital servo? I have both a few TowerPro MG966R digital and some Hobbico CS-70MGBB to choose from.
    Dave
    Quote Originally Posted by HeyOK View Post
    ... I could probably come up with a winch driver circuit for about $20 that wouldn't drift at all. Would that interest you guys? If a couple of people commit to this I will do it.
  3. #33
    Code454 Guest
    i think i got some servos, i might try it as well
  4. #34
    Burnaby, BC
    As long as the motor runs from two wires (ie not brushless) it should be fine. Might be a bit of a challenge to fit it in a servo, but I think I can!
  5. #35
    Rockfrog Guest
    Even external works for me ... I thought you meant to fit it inside the case was all.
  6. #36
    Burnaby, BC
    I'd like to see it fit inside the case too. If not, it would probably be a blob of heat shrink on the end of a servo cable with a pair of wires that you would solder to the winch's motor.
  7. #37
    Burnaby, BC
    Did some R&D this morning. Got things figured out and just have to order a motor driver IC. This is going to work!
    Uses a PIC and a motor driver IC. No more winch drift!
    Hopefully I will have a few of these built by the end of the week.
  8. #38
    soleslaw Guest
    Whoa that was quick!
    There are alot of components there....how small do you figure this bad-boy will be?
  9. #39
    Code454 Guest
    Sweet that was quick lol... and there are alot of components for testing i beleive once you figure the parts out the its just as simple as putting all together and making it work without the testing board lol
    i wish i still remembered how to do that stuff from school, but no such luck lol
  10. #40
    Burnaby, BC
    Sorry... rather than put away components I'm not using, I just jam them into the left side of the bread board.
    There is a bunch of stuff left in the circuit from my Dual Motor Dig Controller that aren't really needed for this build.
    I should be able to make it a little smaller than the driver circuit board that I yanked from the Tower Pro servo. Should be two little 8 pin ICs and a small cap and a bit of wire.
