Results 1 to 9 of 9
Thread: My Axial SCX10 III Build
    Quebec, Canada
    Default My Axial SCX10 III Build
    Hey all! Some of you may have noticed I won the SCX10 III in the 2020 SBG Giveaway!! I was so excited when I read my name in the Giveaway thread, it sure did enlighten the holiday. My other scale crawlers are pieced together from scrap and leftovers or salvaged from a much worn chassis. This will be very different!
    I received it a few days ago, I thought I'd make a thread for it in the general builds section, it has quite a bit of details out of the box so for now I plan to build it stock, except maybe different wheels since I find the stock ones quite big.
    It was packaged in that nice deer wrapping paper! I found it a nice attention So I set up with everything required for the assembly, got some new hex bits, MIP ones in 1.5, 2.5 and 3mm, they feel great! First set of quality hex bits I got.
    I don't have an actual power screwdriver for it so I used this dewalt driver, I was just very careful not to let it actually do the final tightening (did it by hand).
    Axles and shocks done, now moving on to the tranny. Lots of parts! It was very satisfying to build though. Lately, what I've been building (the Escort mostly) was always tedious, design, cut, mock up, won't fit, modify, drill, screw, undo and adjust, etc. Now this thing just bolts on. That's kind of a relief lol
    The tranny is made of many separate parts, pinion and spur, 1st and 2nd gearsets and dig option.
    This is first and second gearsets:
    Fred
    Quebec, Canada
    So I did not take pictures of all the process, here is the mostly completed chassis, just missing the inner fenders and fake engine cover. I used Falken tires I had laying around, glued to plastic steelies. Wrong bolt pattern, but I really like how these tires look, so I'm going for a stock Jeep look on winter tires :) As stock as can be a Jeep on portals, that is!
    Now with the inner fenders, engine cover and battery tray installed.
    And a quick mock up of the fenders on the body, because I could'nt wait to see how the tires look with the body :) I have to say, I love how it looks! Not sure how big it scales up, I think the body is 1:9.4 so if the tires are 4.25" that would be 40"? I think I'm wrong they don't really look like 40". More like 37 maybe?
    Kitchen counter flex shot :)
    Fred
    Quebec, Canada
    Now for the body, I decided on Tamiya PS-12 silver so all the nice molded body details would pop out nicely. I hesitated to keep the roof body color or paint in black so I looked up some reference pics:
    This pic made me think I would regret not painting the roof black, to me something seems way off:
    So after backing the silver paint, and painting the interior, I had just enough black left to do the roof (painted from the outside). It is too shiny, but I'm ok with it. I don't have any clear to go on that, so I will have to do for now.
    And with all the body details and stickers installed, just missing painting the driver:
    For the lights I put and LED kit and put a piece of aluminum sticky tape on the tip of the LED to block the very direct light that looks like a dot. Worked pretty good!
    And that tire fitment, I like!
    Quick run in Quebec snow:
    It was a blast to drive in the snow! I could go wherever my sons left footsteps in the fairly deep snow and only rarely got stuck. I'll have to find a better motor though, I used what I have (stock tamiya silver can) and it overheats even though it is -5 outside. I definitely need a higher turns motor!
    Thanks for looking, hope you enjoyed the pics!
    Fred
    Oct 2020
    Congrats! The final look of this looks really nice! The silver fits well with the black wheels and I love the scale tire choice
    Whee!
    Looks like a solid choice on both wheels, tires, and paint. Nicely done, and quick!
    Quebec, Canada
    Quote Originally Posted by OverlandRC View Post
    Thanks OverlandRC!
    Whee!
    Thanks Matt! I was in fact quicker than the Escort build, I'm almost sure. I said it already, but that's pretty refreshing having everything go together smoothly. Went for a snow run last two days after work, put the remains of a head mount light on it. I guess I'll convert that into a scale light bar, wrapping it in a sintra box.
    On a side note, I do have some transmission slight clicking noise, that does not bother me much. But when I run it off the ground and turn the wheels full lock, it seems like it is periodically binding somehow inside the diff, likely between pinion and ring gear. I noticed immediately when I started assembling the diff that it wants to run smoothly in one direction only (rotate the pinion to make the axle rotate, not the other way around, similar to a worm gear would do). I figured it was because of the pinion being offset towards the top. Did you notice any of that on yours? I might have to open up the front axle if that does not disappear after some more break in time. It also does quite a racket noise when I push it backwards by hand.
    Quote Originally Posted by Frederik View Post
    Thanks OverlandRC!
    That is a side-effect of the high-pinion style of axle. The binding you're feeling is pretty normal with the style of universal at full lock off the ground. Nothing to worry about. One note on transmission construction. The gears are not the same cut on both sides. One side has a rounder area for the pins to seat in. If any of them are reversed, it can introduce some clicking. Not a failure point, just a weird design.
    Very pretty!
    Great job, very clean build!
    Quebec, Canada
    Thank you, appreciate the input, I won't worry about that then. I saw your warnings about the gears cavity being rounded on one side and more square bottom on the other, but I stared at each gear for a good while looking at both sides, and both sides had the rounded pin slot?? It would be surprising that they changed the casting in the meantime? Maybe I just missed what was different, but in the videos and pictures I saw it was pretty clear the bottom was flat on one side, it was just not like that on mine.
    Quote Originally Posted by dagabba View Post
    Very pretty!
    Thanks dagabba!! Feels like I just bought a new jeep from the dealer lol Very different from my other scrappy builds!
