Page 3 of 13 FirstFirst 1234567 ... LastLast
Results 21 to 30 of 129
Thread: Dodge Coronet ‘67 Drag Car Body
  1. #21
    Jun 2016
    Macungie PA
    Doing a little scratch building for the firewall. There will be a vacuum formed cap over the top of this for the cowl. I still need to add a lot of little detail, but the basic shape is there.
    This body will have a flip forward front clip. Not sure the actual name, but it’s basically when you weld the fenders, hood, grill, etc... then put hinges in the front by the bumper.
    Wes
  2. #22
    Dec 2017
    Awesome. I think it's called a clamshell on an E-type? (Being a Brit...)
  3. #23
    Jun 2016
    Macungie PA
    Thanks, its very frustrating searching for picture of something when you have no idea what its called. I will give clambshell a try.
    Wes
  4. #24
    Oct 2017
    Portland(ia)
    Usually on a drag car that's called a flip-nose or tilt-nose, and it's usually a one-piece fiberglass piece that replaces the steel hood and fenders and support stuff. It's much lighter than all the steel, which is I think the main reason they do it.
    Looking awesome by the way! I really admire your builds.
  5. #25
    Jun 2016
    Macungie PA
    Quote Originally Posted by markbt73 View Post
  6. #26
    Mar 2014
    Galway
    Wow! This is awesome. My grand-father had a 67 Coronet 440, blue with a white vinyl top.
    The pulls you're making are excellent. Do you have any pics of your set up? What do you use for the bucks...MDF, hardboard, etc?
  7. #27
    Jun 2016
    Macungie PA
    Quote Originally Posted by Willezcr8 View Post
    Here are some videos of the process. Mostly MDF, but I add on plastic bits and other fillers as needed. Thanks!
    Wes
    https://youtu.be/jDJ0sL9jNy0
    https://youtu.be/BjiWDsNFaeA
  8. #28
    Jun 2016
    Macungie PA
    Here are some updates for the Coronet. Getting close to having the main body finished. Will need to shift to the front clip next.
    Wes
  9. #29
    Mar 2014
    Galway
    Very cool video's...thanks. Pretty straight forward. I've been trying to find the MDF but all I can seem to find is the rougher particle board. Do you have a source you order it from or local supplier that sells it?
    I was truly intrigued by your vacuum tank and compressor set-up. Lots of very good tips throughout the video's also.
  10. #30
    Jun 2016
    Macungie PA
    I get it from Home Depot. Glad the videos could be helpful.
    Wes
