Thread: Shock issues help needed
    Default Shock issues help needed
    Hi all,
    I have an scx10ii and bought a set of proline pro-spec scaler shocks. I fill them with oil just bellow internal threads pump the shocks about 10 times let them sit and do another 10 or until there is no air bubbles. Cannot for the life of me get the full compression out of the shocks. They bottom about 5 mm from full compression.
    If I remove oil to the point where I get full compression I can hear it sucking air and when I open them the oil is full of air bubbles.
    Anyone know what I'm doing wrong here any help or tips would be greatly appreciated.
    -TIA!!
    Sent from my CLT-L04 using Tapatalk
    First part sounds like over-filled but...is the end of the shock with the piston hitting the cap preventing full compression?
    Sounds overfilled. Some shocks need some air, otherwise, it's a hydrolock and fluid won't move.
    Nov 2017
    Nova Scotia
    I had the same this with a friends and we did same as imthatguy is telling you and that helped but my friend felt that they moved to slowly so then we put some thiner oil and then it was fixed for him. I liked them moving slowly, looked more real. Hope that you get them working just the way you like it.
