LockedUp RC
Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 31
Thread: [AgA] - TF2 LWB - 4 door hilux
  1. #11
    Apr 2018
    Quote Originally Posted by Desmo View Post
    Like how you did the leafsprings.
    Hi mate!
    Had a set of red super soft laying around.. Used them to wrap around the original leafs..
    It makes it harder than only the black ou red, but not so hard than 2 black leafs..
    Seems ok to me, but for sure only after testing it.. (y)
  2. #12
    Apr 2018
    Well, every time closer to test it..
    chrome delete at its finest!
    all assembled, it looks about ready for scratching!
    I'm realising that the dual leafs are a mistake..
    Thr travell of the suspention is good, but not great :|
  3. #13
    Can you elaborate on the "o-ring mod" for the springs. What is it? And what does it do?
  4. #14
    Apr 2018
    Quote Originally Posted by Mack View Post
    The oring mod is to put a oring on each leaf to axle bolt, between the leaf and the axle.
    It alows a bit more movement of the axles.
    If you pay atention to the pics you can see the leaf-oring-spacer-axle (y)
  5. #15
    Apr 2018
    this last days haven't got a lot of time on this build, but still....
    started on the wires..
    cuted out the lexan for open windows efect..
    and test fitted mr Spaulding Sir on the bucket seat, this will be his truck!
    also decided that 95mm tyre is not enough for this hilux..
    bought a set of rc4wd wrangler mt/r with 106mm and a set of GRC classic 1.9
    lets see if that's it!
  6. #16
    Apr 2018
    got a little more time, wheels are in!
    this GRC's even have air valves to glue in!!!
    perfect fitment!!
    and for me, the right rear tuck in
    think the wheel/tyre problem is solved!
  7. #17
    Mar 2018
    looks good with those wheels
  8. #18
    Apr 2018
    Thank you Sir! (y)
  9. #19
    Apr 2018
    humps and bumps!!
    the wiring and LED system is finished, all the lights conected to the controler, plus reverse lights and a relay for stop light..
    made some side plastics to hide the wires coming to the reciver box..
    shape defined with paper
    cuted 2 bits of plastic
    and wraped with mate black vinil..
    with the body mounted fits perfect!
    tryed a few combinations with the leafs and the final result for the first field test is achived!
    only the stock leaf with the smaller one on top for reinforcement..
    also changed back to the stock LWB leaf rear mounts, the RWB ones were tending to make the leafs crazy
    had to make some 2mm spacers to get the transfer case down, also 2mm spacer on the steering link to servo (it was hiting the motor)
    for now it sits like this
    the home made transfer case mount and guard looks awsome, if i may say!
    as far as suspention travel, think this is ok.. adapting only the original pieces and not going crazy with aftermarket parts
    as you might noticed, i've mounted the rear plastic original bumper.. removed the awfull corners and heat treated it for better fitment.. not perfect, but will do the job for now..
    i'm waiting on my orders of the rc4wd full interior, cchand bed toyota decal, and team raffee bucket seat arness to start on the interior..
  10. #20
    Nice color choice! Really coming together nicely.
