AE Element
Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 42
Thread: Scale Oregon TrailíR Terradrop Alpha Off-Road Teardropish Trailer
  1. #31
    Well, had a bit of time and made a door kit today. Two actually.
    Bit of plywood, Acrylic, Polybak and a sticker all fit together like so. I love the close tolerances.
    It'll look something like this. But with hinges, which are lost in the mess of the bench.
    I also cut a chassis out of 6mm plywood and painted it black. I may still 3D print it or make it out of brass. This was quicker and easier though.
    Tried the front box. It'll look better when it's glued on.
    Here's the bottom view. Needs a couple of more screws at the back.
    Also put in a couple of pieces of veneer on the top shelf of the galley to cover up the joints.
    Axles and leaf springs are up next.
    Cheers eh!
    Todd
  2. #32
    Looking good! So what is the veneer made from? Is that really thin MDF?
  3. #33
    Thanks Noob. The veneer is is just a really thin piece of birch. About 1 mm thick. You can get veneers from most wood types.
    Cheers eh!
    Todd
  4. #34
    Jul 2017
    Concord, NC
    This is a really cool project. Great use of the laser to create something awesome.
    -Jeff
    Mod19RC Shapeways Store
    IG: @RexRacer19
  5. #35
    Thanks Jeff. This is trailer prototype #2. Lots of little things that need to be fixed for Mk. III. Still definitely a work in progress but lots of fun.
    Cheers eh!
    Todd
  6. #36
    A bit of Tamiya Smoke PS-31 and I have tinted windows. Here they are mocked up.
    Cheers eh!
    Todd
  7. #37
    And now the wait is on. Need M1 X 8 bolts and nuts for the hinges. Hurry up mailman!
    Cheers eh!
    Todd
  8. #38
    While waiting for the tiny door hardware I decided to recut the chassis.
    Here's V2 but the holes for mounting the suspension are too big.
    So, on to V3, smaller holes, still bigger than they need to be though but they'll do for now. Trimmed the chassis up a bit to match the shape of the suspension brackets.
    I 3D printed the suspension. It's not going to last as all I had was PLA but I'll redo it using PTEG most likely. I modified the suspension that Ossum posted to Thingiverse for his M416 Trailer. Basically just made it wider.. We'll see how that goes.
    A view underneath.
    Didn't have any threaded rod for the axle but a bamboo skewer will work for now.
    The fender is also from Ossum's trailer. Need to redo the galley hatch as it's not quite square.
    Cheers eh!
    Todd
  9. #39
    Busy week so I didn't get too much done. I narrowed the fenders by 10mm and reprinted them. Prototyped a side using white mat board (it cuts so nicely on the laser) to get the bolt holes for the fender in the right place. Looks a little better with the narrower fenders I think. I'll recut the plywood sides with the bolt holes for the fenders and hinge screw holes in V3.
    Cheers eh!
    Todd
  10. #40
    Still waiting on the 1mm hardware for the hinges. Got the nuts but no bolts. I printed some new fenders that are more in the style of the TerraDrop Alpha. Here they are right out of the 3D printer. A bit of cleanup and some sanding and paint and I think I've got it. Spent some more time redesigning a few little bits for V3. Hope to cut it this week. It will also have pre-cut holes for the fenders.
    Cheers eh!
    Todd
