Page 1 of 5 12345 LastLast
Results 1 to 10 of 42
Thread: Scale Oregon TrailíR Terradrop Alpha Off-Road Teardropish Trailer
    Default Scale Oregon TrailíR Terradrop Alpha Off-Road Teardropish Trailer
    Not sure how I got to looking at teardrop trailers but my web wanderings led me to the Oregon Trailer site and I was quite taken with the off-road Terra Drop Alpha. I don’t want a real one but I thought it might make a cool model to tow about. Here it is:
    Here’s the kitchen.
    They’re basically made of plywood on a steel frame so I got to cutting out some trailer shapes out of 3mm plywood ‘cause that’s what I had.
    Started gluing bits together and it began to look trailerish.
    Glued some styrene sheet onto the top and added a bit of a kitchen.
    Then I made a hatch for the kitchen but it was a mm too wide and 6mm too short. It didn’t fit.
    So back to the drawing board. Made a new one, a bit narrower and a tad longer, and it fits like a hatch!
    Stay tuned. More to come.
    Cheers eh!
    Todd
    So clean. How'd you cut all these parts?
    I’m lucky enough to have access to an 80 watt laser cutter at work. If you can draw it, it’ll cut it.
    Cheers eh!
    Todd
    That is very cool! I love that it's wood!
    Just like the real thing.
    Cheers eh!
    Todd
    NoVa
    Wow that's cool!! Well done!
    Thank you.
    Cheers eh!
    Todd
    Got a bit more done today. Glued a styrene skin on the hatch cover. Just gotta let it dry now.
    And then I'm going to try to glue this onto the skin of the hatch. This is cut from Polybak, which is a polymer impregnated Kraft liner board. It laser cuts beautifully. This is .66mm thick. Might be too thick to bend properly. Not to worry though I also have it in .30 mm and .12mm thicknesses. I'm using the .30mm for the roof liner inside the trailer.
    This is what I'm trying to recreate.
    Cheers eh!
    Todd
    So, I'm re-skinning the hatch. I put the piece with the name on it on upside down. D'oh! Such a bone headed move. Not to worry though, it's so small there's not much to it. I managed to peel off the styrene from the frame. Here's round two of skinning the hatch. I'm trying Polybak this time instead of styrene. I need to glue it three times because of the curves on the hatch. Never used so many clamps for such a small thing.
    Cheers eh!
    Todd
    Got a bit more done. Glued on the first layer of the hatch skin. Also got the front box framed out. Stay tuned. More to come.
    Cheers eh!
    Todd
