Page 1 of 8 12345 ... LastLast
Results 1 to 10 of 76
Thread: Kamaz Inspired Dakar Build - The Tekin K55
    Jul 2016
    ID
    Default Kamaz Inspired Dakar Build - The Tekin K55
    Earlier this year we finished the first Dakar rally truck build based off an M1079 concept, dubbed the M-55.
    DAKAR-Rally-Modified-Stewart-amp-Stevenson-M1079
    The build was so much fun that we decided to follow it up with another. This one will be based off the Team Kamaz Master 4326 Redbull trucks. Just like last time, here's the concept for the Tekin K-55 Rally Truck.
    To change things up a bit, I decided it was appropriate to go 2.2s and run RC4WD ZXL 5.2" military tires as the real Kamaz run 52" tires. The build sheet is almost identical to the M-55:
    Chassis
    Custom 3/8" Aluminum C-Channel
    Electronics
    Tekin RX4
    Tekin ROC412HD 4200kV
    Tekin T-440 Servo
    Spektrum SR2000
    ESS One Sound System
    Lots of LEDs
    Transmission
    Axial SCX10-II w/divorced transfer case
    Front Axle
    Vanquish Currie F9 SCX10-II
    Vanquish Knuckles
    Vanquish Knuckle Bushings
    Vanquish Spiral Cut Ring/Pinion Gears
    Vanquish Spool
    Vanquish 12mm Wheel Hex
    Incision VXD Shafts
    Fast Eddy Bearings
    Rear Axle
    Vanquish Spool
    Vanquish AR44 Axle Shafts
    Fast Eddy Bearings
    Wheels & Tires
    Vanquish 2.2 Method 105s
    Vanquish .600 Hubs
    RC4WD 2.2 ZXL 5.2" Tires
    Suspension
    RC4WD King Shocks
    Vanquish Trailing Arms F/R
    Vanquish Currie Anti-Rock Sway Bars F/R
    Incision Bomber Rear Links F/R
    Buckle up for another 3D printed adventure! Always fun to start with a pile of goodies picture.
    TEKIN, INC.
    Jul 2016
    ID
    First order of business, duplicating the frame setup from the M-55 truck so I reprinted the center drop skid and battery tray pieces out of Makeshaper ABS.
    Once everything was drilled out and test fitted, I started driling holes in the fresh cut frame rails and mounting all the pieces up.
    TEKIN, INC.
    Jun 2017
    gonna be another great one!
    Jul 2016
    ID
    Axle assembly was smooth sailing, Vanquish Products Currie F9s are a joy to assemble. All Vanquish parts and some Fast Eddy bearings to finish them off. Decided to go all grey underneath on this one since the truck is dark schemed.
    Bomber trailing arms for the front and rear.
    Axles mounted to the chassis with Incision Bomber stainless upper links. Servo bracket for on axle mounting.
    TEKIN, INC.
    Mar 2018
    i will wait for the end, because you prove multiple times, that it can´t go other way than to masterpiece.
    Um yeah, this is going to be very, very good.
    Wow, first Dakar build was outstanding, this one is sure to please as well! Going to be fun to follow!
    That’s a lot of fancy parts to start with. Should be a good one.
    Jul 2016
    ID
    Some of the RC4WD goodies for the K-55. Mil-Spec ZXL tires and King shocks!
    TEKIN, INC.
    NoVa
    Excited to watch. Perfect tire.
