Thread: Marge the Barge 8x8
    Aug 2011
    Harriston, Ontario
    Default Marge the Barge 8x8
    Time for another crazy build. I had a decent pile of parts laying around and decided to try building something big. One set of scx10 axles have a stage one vanquish kit and xvd's axle shafts, the other is all stock. Setting up the axles to be pass through and have steering was a little interesting to get all the wheels moving in the right direction.
    Instead of having a mess of links going everywhere, i decided on trying a walking beam layout. I still need to have upper links, but the front axle will be 3 link with panhard and the second will be 4 link style. The main beam is cut from a chunk of aluminum.
    Part of the whole look, this truck will have wide fenders like gang planks all the way around the truck. Soon they will be covered with diamond plate styrene. The fender base was heat formed, and I started figuring out how much to cut out of the cab i have here.
    I also made a back to the fender and it will match the frame shape. The body is cut out to the shape of the fenders and will soon be glued to them, once the frame and trans are together in their final spots
    Scale Builders Workshop on Facebook and Instagram
    Very interesting build! Iím definitely going to watch the progress on this one.
    Aug 2011
    Harriston, Ontario
    Lots of changes over the last couple weeks and i was on a bit of a crunch to get ready for a local Makers Market, so not allot of pics. The frame got stretched 5" up front and 6" out back. As well as tabs to mount the aluminum beams to.
    Then i cut styrene to match the frame curves and give a mounting pointing for the fenders and body eventually
    Also got my hands on another set of matching wheels. The basic shape now is roughed out and i can start working on all the fun details
    Just to show for scale a lexan 32 ford body on a ofna drift car chassis, sitting on the flat deck
    Well look at that abomination!
    I LOVE IT!
    Aug 2011
    Harriston, Ontario
    Had some time today to work on Marge today. Started with a front plate to lock the fenders together and drop down around the servo.
    Also created a box for around the servo. It will all be glued down and help to stiffen up the area around it.
    And hopefully once done i will still be able to lift everything up. Its already getting heavy.
