Thread: Beam Axle
    Bedlam and Squalor
    Default Beam Axle
    Hey kids. Interesting question, I think, for you. I want to convert my SCX10 to a beam front axle, as youíd find in a semi, or a really old car. Has anyone else done this? Iím guessing itís likely. Any ideas who makes an axle of the correct width? Iím thinking leaf springs are a given, but no clue beyond that. Thanks in advance!
    Jun 2017
    try looking Tamiya semi truck front axle it is the style you want though the width I don't know about that, also I believe it uses a different hub design then the regular hex so you would have to factor that in as well. hope this helps.
    Bedlam and Squalor
    That’s kind of the direction I was thinking of going. Also, it’s probably a cheap option, so that’s a win. Thanks for your input.
    Feb 2019
    Quote Originally Posted by monkeyracing View Post
    I'm currently using a Tamiya 1/14th truck front axle on my latest 2WD build, and I'd say the distance between the hub faces (the front wheels free-wheel on bearings of course) is about 143mm. You can widen the track slightly using spacers and wheel-widener [barrel] nuts to hold the wheels on, but not too much otherwise you'll increase the arc of the wheel as it steers of course.
    for info. I spaced mine out +7mm each side, as my vehicle is quite narrow overall.
    Hope that helps.
    Bedlam and Squalor
    Quote Originally Posted by JMo View Post
    Hope that helps.
    Thatís great, thank you! Good timing, too. I literally just buttoned up my Slash 4x4 rebuild.
    GCM makes, or made, a 'gasser' front axle. It was really nice because it bolted up to leaf springs, and it took axial hubs on the ends so you could use any wheel. The only complaint I had was it had an extra set of leaf holes set further out than the standard leaf mounts (maybe there was a wider chassis at some point?) so it was a little wide.
    I sold mine because of that width issue... wish I still had it. Maybe they'd do another run if we asked?
