Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: Hc4 Tonka Big Tow
  1. #21
    Jun 2017
    And with everything going into this truck, the tires were going flat.
    So I picked up some deuces wild foams from crawler innovations which are good for rigs over 8 lbs.
    Changing the tires like a boss
    So many wires.
    Changed from my 3ch radio to a 6ch. The air pump is on ch3 which is a dial on this radio. Itís program mixed to ch2 so it speeds up with throttle input, but itís also manually adjustable so I can make it chooch while parked, or idle up for winching.
    The shift servo is ch5, and I found a receiver controlled switch for ch6 to run the smoke box so I can turn it off or on, uh remotely.
    And I ran it around a little.
  2. #22
    Mar 2018
    it look great, but one detail is missing. if it is possible to paint inside of front light to silver color to mach real lights. It is red now.
  3. #23
    Jun 2017
    Yeah. A previous owner painted the whole thing red. Iím going to have to try and knock the lenses out with a punch through the led hole to get to them. It also doesnít help that the current owner grabbed the headlight led from the wrong stack and put it red ones. Someone oughta tell that idiot off for being too lazy to fix it.
  4. #24
    Jun 2017
    Little more progress.
    Got smoke out the stack and headlights are white now
    This little piggy is 6.8kg!
  5. #25
    Mar 2018
    nice. i expect more weight
  6. #26
    Jun 2017
    Did a Labor Day run with some people
  7. #27
    This is really nice. That is a heavy toy... great job.
