Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: Paint Code Spray Paint for Lexan
    Feb 2019
    Moorpark, CA
    Default Paint Code Spray Paint for Lexan
    Hello All,
    I would like to paint my clear Lexan body the same color as my real life truck.
    I have the paint code for Quicksand Toyota Tacoma handy, I just can't find confirmation that automotive paint will work on a Lexan body OR if there is a manufacturer that offers a custom spray paint aerosol cans based on paint code.
    Pic for clicks.
    Automotive paint will not work on a lexan body. Nice Taco. You have to use Polycarb specific paint, like the Tamiya PS series, or Pro-Line's airbrush-able line of Polycarb paint.
    Why don't you wait for the MFAB 3D printed Taco hard body, so you can use real paint on it?
    Feb 2019
    Moorpark, CA
    I just emailed Paintscratch.com to see if they offer something that works with polycarbonate plastic. In the meantime, I did find an enamel based paint from Rustoleum, the color is almost perfect to Quicksand. It's called "Gloss Khaki".
    Would you happen to know if Rustoleum paint with work?
    As for the MFab, I am going to wait a little bit till I order it. It's on my wish list, but I want to break the truck a few times, before doing a replica build.
    Jan 2016
    FortCrawlinsCO
    Honcho body while you build the m Fab how you want it
    Quote Originally Posted by MilkTeacoma View Post
    If the paint isn't specifically for Polycarbonate, it won't adhere, and you'll be sad.
    You can use automotive paint on the outside of lexan as long as you Prime with adhesion promoter. Duplicolor makes it. Itís clear and helps paint stick to anything. Iíve had much success using it with automotive lacquer and enamels on lexan. Just follow the instructions on the can and youíre all set.
    You can use automotive paint on the outside of lexan as long as you Prime with adhesion promoter. Duplicolor makes it. It’s clear and helps paint stick to anything. I’ve had much success using it with automotive lacquer and enamels on lexan. Just follow the instructions on the can and you’re all set.
    Oh shoot, yes, that is an option that I don't think I knew about. Well played.
    Feb 2019
    Moorpark, CA
    Quote Originally Posted by odomandr View Post
    That's a great idea, I do like the Honcho body. But unfortunately I already have an extra body to play with. We'll see how this one will holds up.
    Thanks, I really appreciate it. I don't want to be sad. LOL
    Thanks fellas! All great suggestions. I will post up the results on my I finally decide what to do.
    https://www.prolineracing.com/paint/
    You can mix pretty much any solid color using just red, yellow, blue, white and black.
    Here's an example for mixing a sand color:
    https://trycolors.com/colors/c2b280/
    I recently mixed my own mustard paint using Hobbynox paints using mostly yellow, a few drops of red and a drop of white and black. I used a $35 airbrush, it's not great but it works.
    https://i.imgur.com/qfNo0Rs.jpg
    Dec 2017
    Just to stir the thread a little. I'm no painting wiz. Typically I can get paint to stick perfectly and lay down like glass on an unprepped dirty yogurt container, yet when I take every precaution in the world, I get horrible paint quality and woes! So in typical fashion I did a test of duplicolor that I liked on a piece of uncleaned unprepped lexan. To my surprise, I can't scrape it off and have bent the bageezus out of it and can't get it to even buckle. And that's without the adhesion promoter. I haven't painted the body yet...still bending and wondering about my test piece. I'll probably get the promoter and run with it. But I'm still confused why something that isn't supposed to work is working!
