LockedUp RC
Results 1 to 9 of 9
Thread: Why are flat frame-rails bad?
    Nov 2017
    Vienna, Austria
    Default Why are flat frame-rails bad?
    Hi,
    I am quite a nob in 1/10 scalers, so can someone please answer this question?
    Do not see a reason.
    Weight? OK - but in scalers people often add weight to get a low CG.
    Strength? - Well, those massiv flat framerails seem a lot more sturdy than normal C-channel steel rails.
    Scale look? Maybe this is a reason, donno...
    Why are the flat rails so bad?
    Have bought one of those really cheap flat D-90 frames at Aliexpress (for about 20 bucks) and have built a D-90. In my less than 1 year career in building 1/10 "scale-cars" I have built 2 c-channel crawlers so far, 2 Tamiyas, and this D-90 with cheapest Aliexpress flat framerails (and acessories). Loved to build the D-90.
    Cannot see the reason why these flat rails are "bad" or "worse", please explain to me.
    Maybe it is performance?
    Have to admit, I do not drive my cars a lot, I love building, painting, making electronics and light systems, etc. (also have about 15 micro cars) - but drive them rarely. Have to/want to/do go to the field nearly every single day with good weather, but normally go with my helicopters and planes, and very rarely with a car
    THX for explanation, why I should not buy another cheap flat frame in future (BTW: the Reely Axial SCX10 2 "copy" called Freemen seems to have a flat frame).
    Walter
    Apr 2018
    every where i walk
    I dont know the exact answer....
    But flat steel will flex although it seems quite strong a c chanel is stronger.
    its due to the forming of the steel something with bends is harder to bend.
    Hope that helps
    Matt
    Nov 2017
    Vienna, Austria
    Hi Matt,
    thank you for your answer, but I guess, I cannot agree in this case.
    It is only a guess, but those C-Channel-steel frame rails are IMO much, much easier to bend than those "flat" (but much more massive - so not "flat" at all) rails.
    I am talking about a frame like this one (this is a flat frame, isn't it?), this is what I am using in my D90.
ID:	23522 Click image for larger version.
    Weight/bend ratio is for sure much better in c-channel rails than in massive flat rails, but weight is not a problem in scale crawlers, at least "low Center weight", many pilots put additional weights to rims and axles.
    Walter
    So you mean a non C-channel frame? Yeah, RC4WD has been doing it for years and they’re great. Who says they are bad? Trail Finder 2, Gelande 2. The original Tamiya Hilux had aluminum “flat” frame rails in 81. Does that answer your question?
    Nov 2017
    Vienna, Austria
    Hi,
    guess it was Josh/Harley Designs in one of his elder videos (must have been either the MST CFX-W build or the old live stream to his thoughts on the Axial SCX2).
    Did I understand something wrong?
    If they are not bad, this answered my question - Thank you!
    Walter
    Nov 2017
    Vienna, Austria
    Hi,
    found that even GCM Racing Skeleton frames are flat... would have not asked my question, if I would have checked this before
    However, Josh from Harley Designs repeated this "flat frames are outdated" statement in his very actual SCX kit building video on Youtube. Maybe I understood something wrong, because I am not a native speaker…
    Walter
    Dec 2016
    I think a chassis that is flat and narrow is a bad idea unless you have a lot of bracing to stiffen it up but that’s just a band-aid IMO. In my opinion there are a lot small Facebook business guys making these flat chassis rails really only because it’s pretty simple to manufacture, either with a waterjet or 3-axis mill. I built a narrow flat chassis a few years ago and my high torque servo would actually make my chassis flex, I wasn’t a fan of that. I think the thickness of the RC4WD chassis is fine and to be honest... flat is easier to mount items to as well. Also the thickness of the TF2 chassis is that thick to make it easier to mount leaf springs to. The SCX10 chassis with the c-channel design is pretty rigid and when I make my own chassis’s out of .5” square tube I cut it down to the middle to have a c-channel.
    Nov 2017
    pineapple under the sea
    Flat is perfectly fine but you need more cross members to stiffen it up. It can be as simple as putting a few standoffs in strategic places. I dont get where people claim flat rails are bad....
    Jun 2016
    Macungie PA
    I don’t think flat rails are inherently bad. However to get to the same level as c channel rails you have to do a lot more. This is obviously excluding thicker aluminum rails. You can achieve the same thing with both, just requires a lot more structural cross braces. If you are trying to cram a bunch of scale stuff in, adding additional braces for strength can be a challenge.
    Wes
