Page 7 of 10 FirstFirst ... 345678910 LastLast
Results 61 to 70 of 97
Thread: Dag's SCX10ii Hilux
  1. #61
    Jan 2019
    If you are looking to narrow the 1.55's, rc4wd does offer a very slim, pin mount for them.
    https://store.rc4wd.com/Reduced-Offs...ls_p_5444.html
    1.55's always look great on the hilux.
    This hubs works with trx4 axles if I put a pin like scx10 ones?
    Thanks
  2. #62
    Dec 2017
    Quote Originally Posted by Taper View Post
    Thanks
    I don't know I'm afraid- don't have a TRX4 to try it on.
    Someone else might know though?
  3. #63
    Dec 2016
    NoVa
    Love the weld!
  4. #64
    Feb 2020
    Doh, Hilix...
    Talking of unoriginality... Had a go at I'mthatguy's snotty weld trick. Fun.
    Attachment 33645
    And tidied the rear up- blended the sides in, added faux hinges, chamferred in between them and built up the sides of the light buckets:
    Attachment 33646
    Love the work on this. Wow.....
  5. #65
    Dec 2017
    Thanks Harold!
    I'll do one with shiny paint like yours one day... this will not be it though!!
  6. #66
    Dec 2017
    Love the weld!
    Thanks GTR, much fun!
  7. #67
    Jun 2016
    Macungie PA
    Bed detail turned out great.
    Wes
  8. #68
    Dec 2017
    Quote Originally Posted by wesmade View Post
    Wes
    Thanks Wes!
  9. #69
    Dec 2017
    A couple more chassis mods.
    Rear shocks are now angled up straight to the frame so the drop bed can sit flat on the rails. These 70mm jobs are a little too tall, I've tried the 1/18 40mm ones (thanks shopGTR), for a lifted crawler they're a tiny bit short... so I'm probably going to try some 60mm next. One more option is to lengthen the rear links a tiny bit so these have more lay down. Need to get hold of some m4 spacers then I can try that.
    Also I've totally bodged the slipper clutch- by removing the spring (using a brass bushing as a spacer... look away engineers...) I've been able to cut down the shaft so it doesn't foul on the drop bed. Anyone have an Incision Slipper Elimimator they can measure for length against a normal assembly? Might look slightly less home grown...
  10. #70
    Feb 2020
    Hahaha loving the progress of this beast of yours my friend. An absolute inspiration for me.
