Page 6 of 16 FirstFirst ... 2345678910 ... LastLast
Results 51 to 60 of 156
Thread: 1957 Ford F-100 Short Bed
  1. #51
    May 2015
    this doesn´t need comment. those tires fits it
    Glad they do!
    Отправлено с моего NEM-L51 через Tapatalk
  2. #52
    May 2015
    Quote Originally Posted by OldfartRC View Post
    That is incredible!! All that flex too - with LEAFS!!
    This is real Craftsmanship. I look forward to seeing more!
    You had not mentioned... What Scale??? I went back and read entire Thread, in amazement, but could not find even a hint.
    Or is Scale irrelevant in such Art? 1:7th? 1:6th? Must be somewhere around there!
    I must tell you, that is the first time I've ever seen AR60 Axles look small!! And the ONLY time I've seen enough weight, to make Leaf Springs work the way they were designed.
    Haha thank you!
    You were right. It is 1/7 th scale.
    I love ar60 very much, so when i build another truck it will be on the same axles or chassis.
    Leafs work pretty nice with its weight. It has about 40% sag, and work through all the travel during articulation but dont hit the frame. Surely will play with more leafs or another mount for them. For now the frame has only two option :
    Working as on the pic above
    Working like it doesn't hit the frame if i drop it from 30cm height with the same leafs.
    Lots of fun building this one.
  3. #53
    Feb 2017
    You've Certainly got enough weight, to justify Leaf Springs!!
    I don't know if you've considered this... But Shocks were briefly mentioned before. With the sheer SIZE of this Beast, using Axial YETI Rear Shocks - without the Springs, on all four corners of the Truck, should give you ample Damping...
    And in 1:7th, would look really Scale! Just a thought....
    I'm a big fan of the AR60 Axles myself. I've only got ONE running Rig for now (I'm poor), and it's a Wraith. Very capable and very strong Axles!
    ____________________________________
    Carmine A
    Wraith "Spawned"
    CC-01 Landfreeder - Broken
    TT-02 - no Body!
    CW-01 Lunchbox - no Body
    Project "Junkyard Dog", HG P402, waiting for a stock SCX10 One Chassis
    Last edited by OldfartRC; 10-10-2018 at 01:59 PM. Reason: Just getting there first! :P
  4. #54
    May 2015
    Hello guys!
    I found the material for windows. It means that all the left work will be done way faster. Also did the lines on it.
    Sorry for lack of updates.
  5. #55
    May 2015
    And the anti wrap link added
  6. #56
    May 2017
    This build is fantastic! And one of my favorite fords ever. Keep up the artistry.
    If you build it, We will watch!
  7. #57
    Jan 2015
    Speaking from expertise on wrap around windows....
    Not an easy task to get one in their and fitting correctly.
    Looks like you nailed it again....freaking awesome.
    Loving this little truck.
    More please.
    Run what Ya Brung.
  8. #58
    May 2015
    Quote Originally Posted by Woodtick72 View Post
    Thank you!
  9. #59
    May 2015
    Hello, Mr Beers! Thank you
    This is just testing photos, i try to figure it out with some cutted cables around the windsheild now
    More please.
  10. #60
    Jan 2015
    Yes Yes Yes..
    Fantastic additional detail.
    Really a wonderful build.
    Stay the path.
    Run what Ya Brung.
