Page 1 of 2 12 LastLast
Results 1 to 10 of 19
Thread: #PaskudaProject Corolla Ke70 build..or at least my take on it.
    Jul 2018
    Default #PaskudaProject Corolla Ke70 build..or at least my take on it.
    After I sold my ke70 wagon, Ive been meaning to do another one but a little more cooler. So, thought Id try my hands on a sedan version. Why not, right? It is the coolest Corolla ever made. Thats not even my opinion, thats a fact folks.
    Out with the old
    My inspiration
    And in with the new..WINGIN' IT
    Any tips and tricks as to how I can get full roll down on my window or anything else along the way would be HIGHLY appreciated.
    Thanks,
    -Matt
    Smithfield, RI USA
    What you drifter guys can do with lexan is very impressive...! Love the old wagon. This should be great.
    Jul 2018
    Thanks. We too like to be scale
    Started reworking the bumper to match the actual car. Not really sure what particular year he is running or from what generation but I can tell you its a pain keeping the contour of the lexan in check. Need to let it dry before I can finish sanding it.
    Also finished these gems. Waiting to dry so I can shorten the cooling fins on the oil pan to make a little more scale.
    Timing chain cover
    Jan 2015
    I'm really enjoying your work and builds .
    Thanks for the pm also on wheels. Very appreciated.
    Keep the refreshing build techniques coming....
    I'm eating it all up.
    Also..Not sure what you could do for door window windings question.
    Your gear and teeth are about maxed out for size already...lol.
    Ive seen pulleys and rope used...but yours look more correct...Run with it.
    Run what Ya Brung.
    Jul 2018
    Thank you sir. Its probably because i copied the parts for a real manual crank window actuator. Wont be able to see it unfortunately with the door frame skin on. Also one would need tiny fingers to manually crank it. My fat fingers wont cut it.
    So, can anyone point me in the right direction on how I would go about making a header? Honestly couldn't find anything.
    Dec 2016
    NoVa
    Really cool work you've done here.
    Jul 2018
    UPDATE
    First set of ITB's and runners
    Since the shorties were uneven and didnt provide enough high-end power, I decided to make a longer set. Plus
    Corollas have a reputation of being screamers up top so I built to suit. Plus they came out more even second time go
    Trying out a couple of finishes but ended up going with gold to match the pulleys
    Bending styrene over the stove..Its a lot worse than it sounds. Only after my apartment smelled like burnt hair did I come to the conclusion that I need a heat-gun..
    The plus side is I learned to make headers. Downside is they came out like racing headers. Im quite content to be honest.
    Thanks to the pictures of builds on this fine forum, I shorta (kinda) made a thing that resembles a engine.
    If im honest, its not light. I may or may not end up drilling the pistons out to save whatever weight I can, as I still plan on using this when completed.
    -Matt
    Apr 2018
    every where i walk
    Just wow......
    Just wow............
    Matt
    Subbed
    If In Doubt Give It A Clout.
    Sep 2015
    Nice!!!! i love all the corolla family :)
    Dec 2017
    Such nice work!
