We are happy to now carry Savox servos and already have 2 models in stock!
The Savox SA-1230SG Monster Torque Steel-Gear digital servo is ideal for those requiring extra torque, but not using high voltage as a power source.
Features:
  • Extremely strong unique steel gears ensure long-life and durability.
  • Ideal for steering on rock crawlers, monster trucks, and large scale aircraft.
  • Slightly taller case design.
Specifications:
  • Torque @ 4.8v - 30.0kg/416.6oz-in
  • Torque @ 6v - 36.0kg/499.9oz-in
  • Speed @ 4.8v - 0.20 sec/60 deg
  • Speed @ 6v - 0.16 sec/60 deg
  • Dimensions L x W x H (mm): 40.3 x 20.2 x 44.9
  • Weight: 79.0g
The Savox SB-2230SG Monster Torque Brushless servo contains unique steel gears to accommodate the massive output torque of this servo in a slightly taller case design.
Features:
  • Combines leading edge technology with super high 12 bit (4096) resolution.
  • Ideal for giant scale aircraft, monster truck, and 1/8 scale off road.
  • Brushless motor provides longer life and cooler operating temps.
Specifications:
  • Torque @ 7.4v - 42.0kg/583.3oz-in
  • Speed @ 7.4v - 0.13 sec/60 deg
  • Weight: 84g
Don't see the model you want?
Drop us a note and we will get what you need added!
Thanks for reading.
