Thread: Nylint vintage. Build. Opinions please
    May 2018
    Default Nylint vintage. Build. Opinions please
    So ive been thinking about turning a nylint stamped metal truck into a crawler . I figure the conversion should be ez enough. They have real patina. Is it to far from scale ? Whats the forums thoughts . Ive searched the forum with no hits. What doy yall think.? Kinda looks narrow but would. Be ok with those semi rockwell 2 1/2 ton looking axles i seen on the rc4wd store. Suggestions please
    Sent from my LGLS991 using Tapatalk
    These are pretty tiny bodies. This is why they are not used very often.
    As for axles, Losi MRC/Vaterra slickrock and perhaps that new team associated ford truck both have small narrow axles that might work.
    May 2018
    Quote Originally Posted by Small Factory View Post
    Thanks. I looked into the slickrock axles seem they may work. You happen to know of any stamped steel bodys of the same vintage that may be a little bigger?
    May 2018
    Well my nylint tow truck arived and. Small factory. wow did i under estimate how small it was. So now my sun has a new lamp.
    Jun 2014
    Quote Originally Posted by Bent hinge pin View Post
    Did you ever build this ? The Wpl C-14 chassis is pretty close
    Aug 2019
    Cool lamp! It'd be really sweet if you'd been able to do like christmas light bulbs for head and tail lights
    The 1/16 'Redcat Everest' rock crawler axles are a little wide but work pretty well under the 1/14 & 1/16 scale stamped pickup trucks, 'Venom MiniGiant' axle widths worked even better back while they were available.
    I've run converted Structo and Tonka trucks.
    I've got a converted Nylint Crane.
    I'm converting some Doepke equipment.
    Dec 2019
    Have you considered any Tonka trucks? From the ones I have they seem to run a bit bigger.
    Aug 2019
    I know it's a long dead topic, but i think i found a better Nylint solution.
    WPL 1/16 scale B- or C- series crawler axles with the street tires on steelies from their D12 line.
    This size works on Nylint 60s era ford pickups, and a uhaul maxi-mover with squarebody chebby cab.
