Thread: 3 Inch Roll Bars for RC4WD Blazer Pickup Conversions
    Jul 2017
    Concord, NC
    Default 3 Inch Roll Bars for RC4WD Blazer Pickup Conversions
    I have designed a couple of old school 3 inch roll bars that work with RC4WD Blazer pickup conversions. There is a single tube version and a double tube version. Both feature two mounting tabs on the top that can be used for mounting lights with M3 screws.
    Single tube version:
    https://www.shapeways.com/product/YK...ionId=65443211
    Double tube version:
    https://www.shapeways.com/product/CB...ionId=65455422
    Here are some pics of the single tube version on my personal build:
    Installation is simple. Put the bar in the location you want to install it and find the center of the mounting flange using a couple of marks. I would recommend starting with the front two legs first, then once they are mounted with screws, locate the rear legs and mark them.
    Drill the center mark with a 1/8 inch (3.2mm) bit.
    Finally, attach the roll bar with (4) M3X8 screws from underneath. They will thread into the holes, but be careful not to over-tighten them.
    -Jeff
    Mod19RC Shapeways Store
    IG: @RexRacer19
    Feb 2013
    Val-des-Lacs Québec
    Really nice
    Jul 2017
    Concord, NC
    Quote Originally Posted by ericdegallargue View Post
    Really nice
    Thank you.
    -Jeff
    IG: @RexRacer19
    Jan 2018
    Great job looks awesome... do you have any plans for some inner fenders also? scx10 ii /k5 Blazer
    Jul 2017
    Concord, NC
    Thanks. I may look into doing those since I did a set for the Hilux.
    -Jeff
    IG: @RexRacer19
    I’d be very Keen on blazer bolt on wheel wells for the SCX10 chassis as well
    I am in the process of building A scx10 ii Blazer k5 build and be interested in any prototypes of inner fenders!!!
