Pro-Line
Results 1 to 2 of 2
Thread: Trailfinder 2 Torque Twist...Swaybar or Preload?
    May 2017
    Default Trailfinder 2 Torque Twist...Swaybar or Preload?
    I have a fully linked TF2 with 55T motor, R3 two speed, coilovers and helicals in the diffs. She has a wee bit of torque-twist/lean in high gear. I put stiffer springs up front and preloaded the passenger rear which helped take most of it out but wonder what others have done?
    I know on 1:1 sway bars hurt flex (hence disconnects), but with the preload I'm hurting the balance of the springs on side hilling.
    Thanks,
    The S.
    Aug 2015
    Very good question, I'm new to the leaf spring set up and was thinking about doing some of the mod you have done.
    Sent from my SAMSUNG-SM-G935A using Tapatalk
