Results 1 to 2 of 2
Thread: How to Move a Mis Drilled Hole
    Jun 2016
    Macungie PA
    Default How to Move a Mis Drilled Hole
    Just a quick video showing one technique for moving a mid drilled hole. This hole was half on half off its intended location. If you don’t want to enlarge or elongate the hole, this is a good option. Just filled in with metalized epoxy and re-drilled the hole in the right spot.
    Nice!
    Top tip: try to use the [video] tags so you can embed. The video icon in the right corner of the thread creation box is what you need.
