Putting on the beadlock wheels was quite the task.
Here's how I do it:
I lined up the holes and fitted 2 extremely long screws on opposite sides for ease of bolting it down. The proper screws are just too short and will not reach the other side at this stage.
I then bolted them down to lock in the beads and press the wheels together. Next, I put in a third screw and bolted it down too.
By now, the wheels are tight and I proceed on to put in the actual bolt on the opposite side of the third screw. At this stage the actual bolts can already reach the opposite side. Bolt it down. (sorry I forgot to take pictures from here onwards.m but I'll try to explain it as best as I can).
I put in the other 2 remaining bolts and I tighten all 6 down.
I then release the long screws one by one and replace them with the actual bolts.
Loosen all 6 bolts and tighten them back in a star pattern just like the 1:1.
This method has probably been done and shared but I thought I would just share it incase it's different.
