RPP UMG
Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Mog II
  1. #11
    Jun 2012
    Northwich, UK
    Not had much chance to progress this due to finishing off the Maz. However over the last week or so I have been playing with Sketchup again and now have a printable and correctly scaled chassis, I have had to split it into two pieces to allow me to get it on the print bed, I also need to model the front shock mounts but I am going to do them as a separate part to by glued on at a later date, as this will allow me to adjust their position to suit the axle position.
    I will probably get a chance to start printing at the weekend,
    so until then thanks for stopping by.
  2. #12
    Jun 2012
    Northwich, UK
    Got both parts of the chassis printed over the last couple of days and then bonded them together. The print went well although I need to revisit the rear body mounts as they ended up to thin to work so for now I have chopped them off. I will probably reprint just the mounts when I do the front shock mounts.
    anyway here are some pictures of the progress.
    More soonish.
  3. #13
    So cool Pete. Is the plan to leave the chassis printed for the full build? How do you think it will hold up?
  4. #14
    Jun 2012
    Northwich, UK
    At the moment yes the plan is run the printed chassis, will it hold up? I have no idea in all honesty, but as I will be doing Mog correct torque tube axles and suspension I hope the loadings on the chassis rails should be fairly low. I am going to bond a metal (probably brass) tube in the cross tube at the rear suspension mounts. The current plan is also, if I can work out how to draw it in sketchup, to have a printed roll cage thus keeping the weight down. The hardest part will be making the transfer case mountings strong enough to cope with the suspension loadings.
