Page 3 of 12 FirstFirst 1234567 ... LastLast
Results 21 to 30 of 116
Thread: Fat Cat Speedster Jag Project
  1. #21
    Dec 2015
    I think the proportions are perfect, side exhaust is awesome! Progress may be slow, but very cool to follow!
    Thanks Joe.
    Saturday I secured the clamshell hood and made a mounting bracket for the front chassis body post. Took it out for a slow spin in the driveway and discovered lots of clearance issues - especially in the front since the tires are rather wide. I have clearance issues in the rear as well when backing up so a little grinding and shaping ought to take care of that. I need to come up with a better mono shock system in the rear so I don't get so much lift and squat when starting forward or squat when backward. There can be as much as a 1/4 inch movement up or down when the power hits the rear wheels and so I have to compromise some on the stance I want to get. I wish I had a better chassis - one with some camber adjustments in the suspension and I hope to build a better one after this project, but that will have to wait. I'll make small changes to this one and eventually build a new one.
  2. #22
    Dec 2015
    Clearance issues fixed. Had a run around the driveway again and it worked fine. Now I have to set it aside as the school year start is going to have me busy and limit my build time (which is already pretty limited), but just getting the body fixed into a one piece lid and getting it workable is a great deal of progress. Now the work ahead is figuring out some fixtures on the body and dealing with cleaning up the bodywork and reading for primer. - Maybe by Christmas!
  3. #23
    2 rides and no video? :(
    keep going,nice work
  4. #24
    Dec 2015
    Quote Originally Posted by cooper View Post
    Thanks. Perhaps once I get things attached and get a coat of primer I'll video a run with it. Right now it's got so much blue tape holding things on that it looks pretty shabby and I've got some more pieces to make for it before I can put it all together.
  5. #25
    Apr 2012
    Van Diemen's Land.
    I love this arches! Very sexy!
  6. #26
    Dec 2015
    Put in some time on some small things. Opened up the headlight openings and the grill opening and might open up the grill some more. I went to work on the headlight buckets, hood vents, and side pipes. I mocked them up, painted them up and will probably have to tidy them up a bit more. I have a busy stretch coming up and this will have to wait again. The back end will require a lot more tidying up.
  7. #27
    Dec 2015
    More small steps. Made headlight covers out of plastic spoons since I didn't have the originals and I enlarged the openings anyway. Squeezed them a little in a vise and heated them just a bit to induce more curve. They came out pretty well but I will probably do another pair. I just needed to see if the process would give a decent result. I widened the grill opening and need to do more touch up on that as well. I'm trying to get more of a Series III E Tupe opening but I might have to make some lip along the sides. I put a shot of my target opening from a real Series III E Type custom. Covered the passenger side of the cockpit and made a poster board template of the windshield and side lights.
    Still very rough and very slow. That's how I roll right now.
  8. #28
    Smithfield, RI USA
    Keep rollin'!
  9. #29
    Dec 2015
    Worked on fashioning some A pillars, and figuring out the windscreen. It's not finalized but is helpful to see how high I think it ought to be and also that getting the arc of the top front just right is harder with no roof to dictate its shape. The polycarbonate sheet wants to dip in the middle.
    The side screens will have a B pillar in them too, but I will wait a bit. Still working on the front grill opening too. More on that later.
  10. #30
    Dec 2015
    Not a lot has been done since my last post as there is not much time, but I have always wanted to put some detail in behind the wheels in the form of disc brakes and an idea came to me. These discs do not spin with the wheels and only have a caliper showing on the front side. The discs are fairly thin aluminum that I cut out with shears, made sure they were flat, and then trued them up by putting them on a drill and trimming them a bit. (The disc shown in the picture is a large metal washer - too heavy and didn't have quite large enough of an outer diameter but it gives you an idea of what I was looking for.) I sanded them while on the drill to give them a scored look. The hub is just a garden hose washer painted red. Lightweight and cheap too. The calipers are sheet styrene. Nothing sophisticated but they helped with the look of the wheels. Hopefully I'll get some time to run it in the driveway this weekend to check for any clearance issues.
    I'm hoping to do some more involved tasks once the holidays hit, particularly body work stuff to get it ready for primering.
