AE Element
Results 1 to 5 of 5
Thread: Lexan body - putty?
    Mar 2016
    Default Lexan body - putty?
    I've got the Vaterra Ascender Lexan/Polycarb body, and would like to "properly" fill in the shallow ridges on the roof/cab (these weren't there on the actual Blazer/Jimmy).
    What would be the best way to fill in these gaps on a Lexan body? I have Squadron Green Putty (tried this, seems a little too brittle even for a shelf queen, but I didn't do any body prep before testing), I have JB Weld Plastic Bonder Epoxy (this seems to leave a slightly greasy/oily residue after drying - again I did no body prep), and I also have Durham's water putty which I have not tested yet. This is my first real build, so any help would be appreciated.
    I also have plenty of styrene and Bondene/Tenax as well...would any of these be appropriate or would you experts recommend something different?
    Thanks in advance.
    We have a body work section, so I moved it there.
    Fixing a lexan body is not an easy endeavour. Squadron won't work. Id' say Shoe Goo is probably your best bet, but you don't have a lot of flexibility in how it goes on. Really, for lexan, I'd just live with it.
    Mar 2016
    Can shoe goo be sanded?
    Quote Originally Posted by avgatbest View Post
    Probably not a good idea.
    Mar 2016
    Shit. Boo well thanks for the quick responses. I may go back to the JB Weld - are you familiar with that stuff leaving a greasy finish? Is that common?
