Thread: scx10 from 12.3" to 13" wb
    Default scx10 from 12.3" to 13" wb
    like the title says, how and what do i need to go from the 12.3" wheelbase to a 13" wheelbase.
    Oct 2012
    Minnesota
    Have to make longer links is a good start
    How do i know how much longer? and how do i make them?
    Oct 2012
    Minnesota
    There is a bunch of youtube videos on it. Most people us 8/32 threaded rod you can get pretty much anywhere and traxxas revo rod ends. In theory you can use the stock links for measurement, add 0.35 (8.89 mm) to every stock link and you should get pretty close (13-12.3=.7 .7 divide by 2=.35) This will lengthen each side equally. I suggest a digital caliper when measuring.
    thank you so much. i'll report back on my build thread about how it goes
    Oct 2012
    Minnesota
    No problem, pretty easy if you own a rotary tool, once u do a couple the rest at pretty easy
