RPP UMG
Results 1 to 6 of 6
Thread: help with sodering iron
    Jul 2015
    Default help with sodering iron
    apparently my current sodering iron just does not cut it... any sugestions for a reliable afordable iron? also what can i use to make custom rollcages out of brass?
    Aug 2015
    I don't know what all you solder but, hakko 936 is hard to beat. I use mine alot. You can get them now for 60 or so.
    Jul 2015
    but that is not for metal welding right?
    Quote Originally Posted by jacareno123 View Post
    If you're looking to build cages or "weld" then you're never going to get there with a soldering iron. The process is called Brazing - and there's tons of Youtube videos and threads all about that.
    Oct 2010
    Blind bay BC
    you will need to use a torch to do proper soldering on brass for cages. butane or small propane. map gas or acetylene for steel brazing.
    Jul 2015
    is there any other way? one that does not involve open flames since i live in an apartment...
