Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Help wiring new truck
  1. #11
    Nope. That does;t work either. Presumably, the other site doesn't allow for hot linking.
  2. #12
    Not sure what is going on but the image works from 2 other sites. Wish I could attach an image.....
    I will try and describe what I am planning on doing. From the deans plug at the battery I will have power going to both the ESC and the BEC. The ESC will have all 3 wires going to the Rx. The BEC will then go to the servo with the power lines and the signal wire taped off. The servo will get the signal wire from the Rx along with a black ground wire. I have decided to go ahead and use the Rx to power the winch as the ESC has a nice 6v BEC.
    Sound good?
  3. #13
    Attaching images is reserved for Supporting and VIP members. Feel free to use a 3rd party image linking source like Photobucket or Imageshack, like I said before. They're free, and super easy to use.
    That said, what you're doing sounds right.
  4. #14
    Gotcha.....and thanks a bunch for the help.
  5. #15
    May 2009
    Ottawa
    What you described should work, get to work!
