Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: economical lipo charger?
  1. #11
    I've been using these for a few years.
    http://www.hobbyking.com/hobbyking/s...40v_Input.html
    $11.44
    I have 4 of these, and passed on another 4 to other people. Uh. It's $12. It works great when you are not in a rush. This charger puts in 650mah, meaning a 6500 battery would take 10 hrs. Most of my crawl batteries are in the 2200 range, and are about half done when I park them, so after a couple of hours it's ready to go. Plus it plugs into the wall directly and no power supply needed. Charges using the balance port only, so in some cases (like the Raven JK where the battery is under 100hrs of other work) the battery stays in the truck permanently and I charge it with the balance port extension.
    And I have a Hyperion Duo II also, which is also my favorite charger, and I barely use it. It is sick though.
  2. #12
    May 2012
    Narrows, VA
    This is what I ended up buying. It's gotten good reviews & in my price range. we'll see.
    IMAX B6
    www.wolfcreekrcpark.com
  3. #13
    May 2012
    Narrows, VA
    Finnaly plugged this thing in & nothing. I've gone past the return time frame. Hopefully they will still honor it since I haven't used it.
    Sort of wish I had gone this route now that I know a little more, not as economical but less than the Duo II:
    http://www.empirerc.com/hyperion-eos...de-p-5412.html
  4. #14
    squatch71 Guest
    like my thunder power 680 50 bucks...everything I want.
  5. #15
    May 2012
    Narrows, VA
    Just a little update here for anyone else looking to upgrade to lipo (I'm so behind the times). I bought the IMAX B6 through Amazon & they instantly refunded my money, no questions asked.
    I then purchased a Hyperion EOS720I NET 3 AC/DC and am real happy with it. The interface is easy to use, lots of memory, decent horse power for an internal power supply.
    My advice: do your research before you buy. There are a lot of opinions out there & it's not a one size fits all deal. lot of variables & worth doing a little googleing before buying.
