Pro-Line
Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 39
Thread: making your own links
  1. #21
    greger Guest
    that helps alot. thank you all for the help hopfully get them all done by the weekend.
  2. #22
    greger Guest
    with using the stock axial ends do i need to tap them out to fit the 8/32?
  3. #23
    Sep 2010
    Abbotsford
    Quote Originally Posted by greger View Post
    yes, you will.
  4. #24
    Heinz57 Guest
    If you use 6/32 you just have to drill the stock ends out a little no need to tap.
  5. #25
    greger Guest
    Hmm so drill out the stock ends and tap to fit the 8/32 the only
    Problem is then my walls
    Are gonna be thin. Do any of you find it gets to thin or still ok?
  6. #26
    greger Guest
    hmm so u dont recommend using the axial ones then?
  7. #27
    greger Guest
    alright well i guesse i will go that route it does seem the best it just sucks seeing parts go to waste..but it will be worth it.
  8. #28
    Dec 2011
    Edmonton, AB
    some parts arent worth having to begin with.... unfortunately that is usually somthing you learn after you already bought them :p6639707:
    i would love to make a dual bend steering rod like that one day.. doesnt look like fun to get the measurements right though
  9. #29
    Dec 2011
    Edmonton, AB
    Quote Originally Posted by Scorpion_Ax View Post
    i don't know why you say they are wasted parts ..... your in this hobby now and i am sure you will use them sooner or later.....chin up bud its not that bad....LOL.... i have got stuff before like this too and had to put it onthe shelf for better ideas and stuff needed so.....good luck with the new links your building
    agreed... heck my 6x6 is probably going to be 80-90% parts that i just threw in the random junk box at one time or another... KEEP EVERYTHING
  10. #30
    greger Guest
    Haha ya I'm or thatttt sad over it lol. Will all be worth it deffently
