LockedUp RC
Page 8 of 46 FirstFirst ... 45678910111218 ... LastLast
Results 71 to 80 of 453
Thread: "The Steelhead" FJ40
  1. #71
    Nov 2009
    Pooh corner, Ont. Canada
    Very nice indeed.
  2. #72
    Mar 2008
    Uppper Riverbank
    Your'all praise, is what fuels me to take my time, and make the parts really nice.
    Thanx.
    GRU & winch showed up today.
    I'll put them in when some free time permits. The GRU will go somthing like so:
    I wish they made the center section outta steel. Coulda just brazed some legs to it, then braze it to the rails.
    For the winch; should I use the stock controller, or just get the Heyok one?
  3. #73
    Mar 2008
    Uppper Riverbank
    Got the new parts bolted in. Still gotta Dremel the clamp-bolt on the GRU mount (forgot cut-off wheel at work). Winch just bolted right in; although, it's housing needed some cleaning-up to sit level.
    I'm waiting for the Split-Skid, before I braze the GRU / transfer-case drive-shaft
    A big-ass Hitec servo is next to get, and tonight I'm mess'n with the body some more:
  4. #74
    Deric Guest
    Very nice work man. I'd get one from HeyOK. Better control and cheap to buy. Keep up the great build man!
  5. #75
    Mar 2008
    Uppper Riverbank
    Thanx Guys.
    Heyok it is...
    Of the few ideas I had for it, this was the easiest one to do. I hope when the split-skid is in, that the drive-shaft angle isn't too steep. I'd have to re-braze, and angle the mount a bit.
    One thing i have on my mind is the GRU bushings. Wonder how long they'll last?...I'm thinking of saving for a Crawlmaster pro 16-turn to put in it, and I'm expecting it to chew-up anything weak.
  6. #76
    Mar 2008
    Uppper Riverbank
    Yes, that will probally have to be done in time. Gears look thin too. I thought that they would be pinion thickness. I could see modded pinions and shafts in the future...
  7. #77
    Looking wonderful as expected!
    Say, I looked back and couldn't find... what brand GRU is that?
  8. #78
    Mar 2008
    Uppper Riverbank
    Thank-you Thank-you.
    It's an RC4WD 4:1 GRU...
    http://store.rc4wd.com/41-Ultra-Comp...or-_p_782.html
  9. #79
    AxNOoB Guest
    Nice build! Will it be a Land cruiser ?
  10. #80
    Mar 2008
    Uppper Riverbank
    Thanx; and yes, it will be a variant of of the FJ40.
    I wish I had the time this week to work on it, but the dam work-busy-ness I wanted showed up.
