Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
Thread: Plastic Weld - Working with Modeling Plastics
  1. #21
    Charlotte, NC
    And tastes great in a smoothie!
    DON'T DRINK IT.
    Too late.
  2. #22
    I used MEK on my Corvette build because I needed very strong bonds. I put it direct on the joints and then also had a jar in which I melted plastic in the MEK - pieces of the same plastic I was joining to form a filler because the regular putty would crack at the least bit of flexing. Once the bond was done I sanded it and then used the regular putty for a smooth finish. And yes, the fumes are really bad so I wear a respirator mask and work in a ventilated space with it. I have used it on my jag project as well and will be doing some more with it as that build progresses. Underneath I am going to join the aluminum deck to the plastic via fabric hockey tape and epoxy resin, but that will be posted in my thread once I am ready to do it.
  3. #23
    I work in a boat shop and assume it's the same Mek I use?
    Sent from my SM-S767VL using Tapatalk
  4. #24
    Quote Originally Posted by Spindctr View Post
    Correct
  5. #25
    Quote Originally Posted by pardonmyn00b View Post
    Correct
    Great! One less thing to purchase. This will be my first experience. Patching the stock hole in the tamiya hilux cab for my truggy build.
  6. #26
    Was wondering if there is a tip for molding a shape. Tried to make a hood scoop but I can't get the bend right. Was looking for something I mold into shape and sand to a finish
    Sent from my GM1917 using Tapatalk
