GCM Banner
Page 2 of 6 FirstFirst 123456 LastLast
Results 11 to 20 of 53
Thread: Race Tractor tribute build
  1. #11
    Feb 2016
    Poland
    Great to be a part of this build : )
  2. #12
    Jul 2018
    Cool! First post here. I've been working on this build as well and lurking around, wondering why I hadn't seen anyone else building the Racetractor. I look forward to seeing the rest of your build!
  3. #13
    Oct 2017
    bit more progress
    Sorted out some extra rear bracing
    Welded in some tubing to the skids that the twin batteries will sit on
    Headlight brackets soldered on
    Permanent front shock hoops tabbed and welded on
    Brackets added for fuel cell and rear radiator
    Quote Originally Posted by Carnitas View Post
    Thanks
    @ScaleBuilt on Instagram
  4. #14
    Dec 2014
    In The Shop!
    Seriously bad ass build! Love the fab work and being based on a 1:1 "Tribute" build, it reminds me of a couple Trophy Rat scale builds. Looks awesome so far!
  5. #15
    Oct 2017
    Thanks - I've definitely been a follower of your previous builds and LOVE the trophy Rat !
  6. #16
    Oct 2017
    only a small update today
    The Race Tractor seems to be pretty minimal for lighting on the rear side, but it's got a single lamp in the middle of the rear roll hoop. Managed to find something similar looking in my box of led stuff so brazed on a stainless bracket for it
    Also finalised the body mounts.
    Bonded a couple of rare earth ring magnets to the inside of the front hood / bonnet and these lower down onto a thin sheet steel plate that runs between the front shock hoops, and the sheet has a couple of sticky up tangs that locate themselves in the centre hole of the ring magnets when the body is lowered down. Then for the rear of the body I've soldered on a 90 degree piece of sheet steel that kind of cups the back of the body. Hopefully it ends up being pretty solid.
  7. #17
    Apr 2017
    Oct 2017
    lots of little things sorted out now.
    Battery trays are now both done and nicely hold 2 x 2200mah 3S lips securely with a velcro strap.
    Soldered on a couple of tabs to the back also that will house a couple of small tail lights I had left over from a Defender build.
    The Race Tractor has a Jaz Products fuel cell in the back
    so I've repurposed and detailed an Axial RR10 Bomber fuel cell.
    Painted it up and detailed the straps / bolt heads.
    then drew up on illustrator a mini Jaz Products decal and printed it out.
    I've also drawn up on the computer scale versions of decals that are on the 1:1 truck - so they'll be next up on the vinyl printer
  9. #19
    Oct 2017
    So
    I’ve started the painting and weathering.
    All painted on the exterior
    Base coat of silver Tamiya lexan paint
    Bit of liquid mask
    Followed by various shades of greens / blues / blacks / turquoise Tamiya TS paints
    Creative use of a sponge, and then a few different washes and then applied the stickers I made.
    Painted up the RC Nerds 3D printed grille
    Then spent some time applying a variety of Vallejo and Tamiya pigment effects
  10. #20
    Jul 2018
    Man the decals turned out great! Really sets it off. I have a friend with a vinyl cutter but wasn't looking forward to drawing them up. Let me know if you're interested in selling a set!
