LockedUp RC
Page 5 of 16 FirstFirst 12345678915 ... LastLast
Results 41 to 50 of 153
Thread: Manitou FJ55
  1. #41
    Mar 2018
    looking nice
  2. #42
    Apr 2017
    I'm watching this thread with a pair of binoculars all the way from Asia.
    What glue do you use?
  3. #43
    Dec 2016
    NoVa
    Thanks guys.
    I used Loctite brand gel super glue. I watched a couple videos, read whatever I could, even emailed Manatou asking if they had a preference of glues. No response from him, and most of the videos and testimonials said regular crazy glue worked best. I glued it all together, then when complete, I added additional glue to all of the joints and unions. Seems quite strong I must say.
  4. #44
    Mar 2016
    I thought PLA was impervious to acetone?
    Thatís what I thought/understood also - all the 3d print nerds on YouTube say so.
    You know whatís good, though? A pen sander. I got my Bronco body and pen sander in the mail last week and decided to try it out on some of the glue seams. Itís pretty delicious.
  5. #45
    Mar 2018
    you use acetone vapors for smooth surface of 3D printed objects. never put any plastic to acetone liquid it will melt it
  6. #46
    Mar 2016
    I'll have to ask Dion what he's printing with. Looks like PLA to me and it's definitely melting the outer layer.
    Edit** It's PLA and acetone is definitely smoothing just as well as my abs tests. We're not talking about dipping plastic into a barrel of acid here. Brushing on or using Acetone vapors to smooth is a pretty slow process that really only effects the outer layers.
    I have also been considering picking up a Proxxon Pen Sander......guess these bodies will be the perfect excuse to pull the trigger!
  7. #47
    Mar 2016
    Default Manitou FJ55
    So youíve tested that method on these PLA bodies?
  8. #48
    Mar 2018
    we use it for 3D printed PLA scale accesories to smooth surface and not peal too much
  9. #49
    Mar 2016
    Doesnít exactly answer the question. I guess someone here will have to actually demonstrate that it does actually work for these bodies. If it does, could be a big deal.
  10. #50
    Mar 2018
    print one test piece, put it into can on stand, put acetone on bottom and cover it for 10 minutes. test piece must be on stand not in acetone. Make that piece with some detailed 3D parts and you will be surprised
    https://www.youtube.com/watch?v=VZUfq0yrtv4
    he do with small vapor content, but goal is to have strong vapor in it, not like he did, that he created vapors and then he left them escape and try to smooth it. But it may be that it will not work that way on all PLA
