Page 2 of 8 FirstFirst 123456 ... LastLast
Results 11 to 20 of 72
Thread: 1966 CitroŽn H
  1. #11
    Oct 2017
    Portland(ia)
    Woohoo, another CitroŽn! Love these gawky things. Looks great so far. I gotta hurry up and finish my home-improvement projects so I can get back to work on the Mehari...
  2. #12
    Jul 2015
    Frankfurt, DE
    Quote Originally Posted by NewGuy View Post
    Looks like a fun build.
    It is that
    Quote Originally Posted by markbt73 View Post
    Do it! Some of the older French cars are epic, if not iconic. The H is right up there with the VW T2. Then there's the 4WD Sinpar Renault 4 which did Paris-Dakar Rally in 1979 and 1980 (came 5th and 3rd, respectively). And of course the indestructable Peugeot 404 - many of which are still daily runners in Africa. I want to do a 1:10 scale version of the pickup, in particular.
    Anyway, back to the H. Got the rear mounted, some of the interior boxed out, and made the wheel arches a bit bigger. Because I'm sticking with the Chinese 未知的品牌 2.2s with the 90mm ⌀ Proline Buggy tires. Body is also super lifted, which I think sort of suits the Wild Willy theme.
    Speaking of themes, I finally decided on a theme for the build. It's going to be a rally support vehicle. Not sure yet whether Paris/Dakar, Ultra 4, or a ripoff Camel Trophy type thing (but with Peter Styversant, Chesterfield, or maybe even art-deco Gitanes).
  3. #13
    Dec 2017
    This is great fun!
  4. #14
    Jul 2015
    Frankfurt, DE
    This is great fun!
    It is that Got the sliding door to slide.
    Swapped the stock 70mm MST shocks out for 60mm RC4WD shocks. Also made some seats, and covered everything on the inside that needed covering.
  5. #15
    Feb 2018
    Very cool, love the sliding door
  6. #16
    Apr 2017
    Nice door, its just missing the "free candy" message on the side panels!
  7. #17
    Jul 2015
    Frankfurt, DE
    Quote Originally Posted by Karl View Post
    Thanks. It's got two sliding doors now (see below)
    Quote Originally Posted by valheru View Post
    Ha! Going with a motorsport crew theme
    So. Did the front doors because they looked like trouble. I was right. Went through 7 prototypes until I got what I wanted. Never make hinges when you're tired!
    The hinge pins are 7mm long. They were easy enough to cut, but hard to get into the hinges.
    Result was worth it though. In this picture the top hinge was still too low and has been moved higher up. The hinges will be hidden/covered as much as reasonable.
    And then I started on the suicide doors. Easy enough, but the interesting part about them was having to look hard at the corrugated body panels. They're not. They're stamped steel. And so I used 1mm thick, 3mm wide strips of styrene to get that effect.
    Going to be a lot of work doing the rest of the van Anyway, with door closed:
    And open:
    Finally, also got the spare wheel in. This is the other sliding door.
    Suspect I'm going to extend the rear of the front wheel arches a little.
  8. #18
    Jul 2015
    Frankfurt, DE
    A bit all over the place with the scale garage, the Skyline GT-R (need to start a thread for that one) and the Mil build off which doesn't know if it wants to be an Opel Blitz or M26 Dragon Wagon. But in spite of all that I got some more done on the H.
    So this side is pretty much done, bar the spare wheel sliding door, which still needs a bit of work.
    Haven't even started on the front
    Right hand side is pretty much there. Could probably use a cap on the fluel tank. That hole is 6mm Ý, so will take the nozzle from my fuel pumps
    The back is like the front - it still needs all the things.
    The interior. Not sure what decorations will go in there.
    And at the garage.
  9. #19
    Mar 2018
    sits too high, but details are awesome
  10. #20
    Jul 2015
    Frankfurt, DE
    It does indeed. Sit too high, I mean. The whole thing is wrong - they were never 4WD. It's supposed to be a caricature build with all the Wild Willies. We'll see what it looks like with paint and reassess. Easy enough to change.
