RPP Winter Vaterra
Results 1 to 7 of 7
Thread: Series II Land Rover
    Jun 2016
    Default Series II Land Rover
    Here is a build I finished right before starting the Scout II. I wanted to make a Land Rover which was different from all others out there. This is why I chose the ones with the headlights inside vs outside.
    Jun 2016
    More pictures
    Jun 2016
    And some more pictures.
    Jun 2016
    Last of the pictures.
    Feb 2015
    Tavastia, Finland
    Happy to see good pictures from well executed and detailed build! Nice blend of different materials.
    Just curious, how did you make the hood and the roof?
    Dec 2016
    NoVa
    Excellent work.
    Jun 2016
    Quote Originally Posted by Halme View Post
    Thanks, I really had a lot of fun building this one.
    For the roof, I built up the edge and then contoured it back. Then I stretched a thin sheet on top[ and bottom. The drip edge was also separate and attached to the body. Once it was all sanded smooth and painted, I glued the white cap portion onto the drip edge portion.
    The hood was just one one sheet of thicker material heat formed around a bucket to get a large radius. I then added strips to the edge to build up the thickness. This was then sanded back to give the profile.
    Wes
    Excellent work.
    thanks, I appreciate that.
