Specifications:
CNC Machined
Yellow Baked Finish
Steel Stainless and Alloy Aluminum Casting
Welded Steel Truck Bed
10 Channel 2.4GHZ Radio
Optimized Steel Hydraulic System
Reliable Hydraulic Valve and Adjustable Pump
Brushless Hydraulic System
All Light Pockets Can be Illuminated with Light System
Full Metal Scale
Full Metal Transmission
Run Time is: 35 Minutes (22000MHA Battery)
32# Hydraulic Oil (280 ml / 9.46oz)
Maximum Bed Lifting Force: 200kg / 441lbs
Maximum Speed: 10KKm per Hour / 6.21MPH
Scale: 1:14
Supply Voltage: 12V (XT90 connector, 3S Lipo Battery)
Minimum Ground Clearance: 3.74in / 95mm
Length: 40.0in / 1015mm
Width: 27.0in / 685mm
Height: 22.0in / 560mm
Dead Weight: 100kg / 22lbs
Manufactured by JDCustoms
30 Days Limited Warranty
Click above to see it in action!!
Shown with RC4WD Trail Finder 2 RTR w/Mojave II Body Set (Z-RTR0024) and RC4WD 1/18 Gelande II RTR with D90 Body Set (Z-RTR0026) for size reference (Not Included)
Just a few days left to take advantage of our END OF SUMMER SALE EXTRAVAGANZA!!
We had a great time at Axialfest 2017!!
Check out our short compilation video of the event. Can you spot yourself??
Did you miss out on seeing the first airing of our Heavy Machinery on GearZ Nation?
Click our blog to check upcoming air dates THIS week!!
