Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
Thread: Hairba11's mk48/17
  1. #21
    Jun 2017
    Thanks. The encouragement really helps to keep up momentum
    Today's work.
    I need to get some strip for the tank details and put a filler cap on and I'll be a work light away from done-ish on the drivers side modifications.
    The HEMTT has a round air cleaner and a tool box and hydraulic tank normally
  2. #22
    Feb 2013
    Val-des-Lacs Québec
    Incredible build
  3. #23
    Apr 2015
    Your really going all in on the scale details! Can't wait for the finished product!
    Sent from my iPad using Tapatalk
  4. #24
    nice progress, loved the out-of-box thinking on the "steerings rams", simplified with servos
  5. #25
    Jun 2017
    Thanks guys. The ram idea works pretty well. I still have to secure the shock bodies but I'll get to those while working out body mounts.
    But wait! There's more!
    Today's progress:
    I rooted in my 1:24 model kit toolbox and found some sheets of 015 and used the paper cutter to make 1/8" wide strips for the tank seam and tank straps.
    I also grabbed an old 6x9 speaker grill
    And cut a square out.
    A little bend and cut later
    And the radiator shroud is complete.
    I added small hinges between the shroud and motor cover so I can flip it up to access batteries etc.
    Then I got some paint on it
    The exhaust goes on the right side and I got a good start on it.
    I used toilet supply line 3/8 copper tube for the pipe, and a grill from an old set of computer speakers with some copper strap and soldered it together.
    A little flat black should hide the sins.
  6. #26
    Jun 2017
    Here's this morning progress
    Exhaust on and painted
    Then I threw some paint on the bed
    I want to do some interior work before I finish painting the cab
