RPP VS4 2018
Page 20 of 21 FirstFirst ... 10161718192021 LastLast
Results 191 to 200 of 208
Thread: M548 tracked vehicle - Cooper
  1. #191
    Quote Originally Posted by iceman88 View Post
    Woooooow!! Awesome!!! You read my mind. The colours are great and the accessory for the gun box is perfect. Well done!!!
    There was nothing wrong with the ammo box you've provided with the drawing. I only wanted to complicate a bit and add my own touch. Had some aluminium tooling foil and a ammo belt from a action figure, so why not?
    Of course, painted looks a lot better...
    Moving to the wheels, started to bolt the hubs
    ...11 wheels to go....
    What do you guys think?
  2. #192
    Hi guys!
    I halted the work on this truck but it's not forgotten. I'm giving more attention to the Unimog because this one already moves and the work left it's cosmetic mostly
    Speaking of moving, upgraded one thing. I was limited to only one of my radios because of the mixing needed to make the truck move. But I also need that radio for the JK so instead of buying another receiver I risked it for a solution 10 times cheaper:Ordered an Hobbywing V-tail mixer.
    Should have done that ages ago. Simply connect the plugs and it's ready. The crappy weather allowed indoor testing only but responds well and didn't fail untill now
  3. #193
    Too much time without updates
    First, the brief test after got the v-tail mixer:
    And this is being silly on sand leftovers from house renovation s. It's running on 3s:
  4. #194
    Aug 2015
    Very cool
    Sent from my SAMSUNG-SM-G935A using Tapatalk
  5. #195
    Quote Originally Posted by snapon12 View Post
    Very cool
    Although they're the same scale, seems that the M548 has been hitting the gym :)
  6. #196
    Short and raw video of it on the beach
  7. #197
    At the moment, the truck is waiting for parts,stripped a gear in one of the gearboxes. In the meantime, did a accessory for Bishop:
    Put the epoxy putty on his head to do the rough shape:
    Closer to the final shape:
    Ear pieces and mic:
    Painted:
  8. #198
    The truck it's still broke so I did a simple thing that should have done long time ago: Glue the cushions for the seats
    and begin to plan the new,stronger gearboxes
  9. #199
    Always good to see some progress on this...
    Thing.
  10. #200
    Thing.
    Yes, life don't give me much opportunity to work on this but is going. Still not pretty, though
    A friend gave me a scale CB radio from Shapeways for my Unimog. The thing is that I never mounted it and it sat for a while in the shelf. But the M548 it's also perfect for it. So, I've finished it.
    The radio was painted black, including inside with nail laquer for the light don't bleed out(more on that later)
    Need the mic so I did a quick one on PVC, the round part was achieved pressing a bearing against the pvc. The rest was dremel and sanding
    Some thin cable wrapped around a wire could make a scale spiral cable?
    I think so:
    All assembled:
    So, there's a LED behind and drilled 1mm holes on the front for the light pass through. In place:
