GCM Banner
Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: CMAX Assembly Instructions
  1. #11
    Sep 2014
    Cary, NC
    Default CMAX Assembly Instructions
    Step 7.2: Linked rear suspension installation
    GCM offers rear link kits to fit a range of wheelbase options:
    - 277mm (10.9") fits from 274-280mm (10.8"-11")
    - 308mm (12.1") fits from 305-311mm (12"-12.2")
    - 330mm (13") fits from 327-333mm (12.8-13.1")
    If you are using the GCM front links, you can also adjust the wheelbase at the front by an additional + or - 3mm. If you are using a body with a different wheelbase, you can make your own links to suit your build.
    Start by assembling your links:
Name:	CMAX links.jpg
    Link assembly video:
    Attach links to side plates:
    Note the use of 3mm spacers inside the c-channel rails for proper spacing of the upper links:
    Attach links to axle:
    [picture to be added]
    Install dampers and coils. If using ECX 1/18 shocks, refer to step 6.5 for mounting instructions:
    Damper installation video:
    BowHouse RC, Helios RC, GCM #tinytruck Team
  2. #12
    Sep 2014
    Cary, NC
    8. Electronics
    Battery tray video:
  3. #13
    Sep 2014
    Cary, NC
    9. Body mounting (1 of 2)
  4. #14
    Sep 2014
    Cary, NC
    9. Body mounting (2 of 2)
  5. #15
    Sep 2014
    Cary, NC
    Reserved
  6. #16
    Sep 2014
    Cary, NC
    Updates:
    12/14 - added rear leaf suspension installation
  7. #17
    Sep 2014
    Cary, NC
    Updated 12/16: Added rear linked suspension installation
  8. #18
    Dec 2015
    Great thread. It has helped me out immensely.
  9. #19
    Sep 2014
    Cary, NC
    Thanks! Glad you’ve found it helpful.
  10. #20
    Sep 2014
    Cary, NC
    In case you missed it, Roo ran into a little snag assembling a t-case this afternoon while Dad was working in the yard.
Name:	Roo at the bench 1.jpg
    So he took it upon himself to post his sentiments thusly:
    HELP HELP THIS THING IS IMPOSSIBLE TO BUILD!!!!!!!!!!!!!!!!!
    But we got through it. Did I mention he's now built more of these things than Dad has...?
